Saleen Brake kit 87-93??
So my buddy has a foxbody GT with a 5 lug swap, but he's also got a Saleen brake kit he says he bought about 6 or 7 years ago. Is there a brake kit out there or a place that stocks a Saleen foxbody brake kit?
89-055 93 Cobra Teal 79 Pacecar |
If memory serves correctly, the rear's were from a Lincoln. I don't recall where the fronts came from.
Yes stock the rears did, my car has the stock brakes. Did Saleen come out with a brake kit for foxes? It's also possible my buddy has sn95 5 lug conversion in the front on his gt. was there a caliper kit for sn95s?
The 87-93 Saleen front brake package was just 11" Lincoln MK VII rotors & calipers, on stock 87-93 Mustang spindles. The rotors are the same basic spec as OEM Mustang, with 1 extra lug stud, and the calipers had a bigger piston than the Mustang. The Lincoln's shared the same brakes as the SVO Mustang. The advantage to the SN-95 setup is the smaller grease hub which allows for wider wheel selection. Also with the 94-04 spindles you can run 11" or 13" Ford brakes without having to switch anything but rotors and calipers.
My wife is the best |
