Old 02-20-2010
siggy_freud siggy_freud is offline
Default Baseline Dyno Run
Here is a video of my baseline dyno run. Other than the extreme cooling upgrade, my car is completely stock.
Anyone else have some stock numbers to compare to? I'm happy with the numbers and look forward to seeing them grow as the modding begins.
My father, who drives a 335i BMW dyno'd at just 10hp under what I did. His automatic is very temperamental on the dyno, as it wont completely hold a gear. Both the tech and us agreed that if he had been able to peg the throttle from the get go, our torque numbers would have been pretty much even.
http://www.youtube.com/watch?v=Mqgt9ejbHzo
Old 02-20-2010
06281E 06281E is offline
Nice! Your pops' 335 made 350whp, what tune is he running on it? There is a special way to dyno those auto 335's, just look it up on Google or e90post... My 335 made 417whp when i was done modding it, those things are making up to 450whp now with bolt ons, meth, and a tune. I was waiting for upgraded turbos on mine but they never came out so i got rid of the car and picked up the 281E.. Nice cars though!
Old 02-20-2010
AMS MIKE's Avatar
AMS MIKE AMS MIKE is offline
SOEC Member (Inactive)
In order to dyno an automatic, you must know what MPH each gear before shifting and with the 335i, use gate shifting in order to make it stay and not upshift. You can floor the pedal ONCE above a certain MPH so it does not shift. Just dont go that extra 1/4", that is the kickdown pedal on BMW's. You hit that, it dowshifts! A properly trained dyno operator should know this, its common sense.
the BMW 335i is one of the EASIEST auto's to dyno.
Old 02-21-2010
The meth and other goodies are ready to be installed on the 335. Looking forward to seeing the end result.
He's running a procede tune by vishnu.
Live and learn. Common sense is relative. Be polite.
Old 02-21-2010
RKN's Avatar
RKN RKN is offline
Siggy: I see that your numbers are stated - "uncorrected with a smoothing factor 5". Below are my dyno results done by AMS Mike at the time my E was built. Mike states that the my correction should be - "SAE and smoothing factor of 0". This does lower the power levels. I am showing both as a comparison.
Uncorrected - Smoothing factor 5
Max Power 477
Max Torque 464
SAE - Smoothing factor 0
Max Power 468
Max Torque 458
BTW Nice car ...are you still contemplating the 475 upgrade??
Rick
2007 Extreme 0042
Old 02-21-2010
AMS MIKE's Avatar
it was not towards you at all, rather the dyno operator. There are SO MANY people out there with a Dyno's and dont know how to operate the car properly on it and in return, the customer gets the short end of the stick. Thats all i'm saying.
Vishnu is good stuff, Shiv (owner) is an awesome guy!!!!
Old 02-21-2010
AMS MIKE's Avatar
Max Power 477
Max Torque 464
Max Power 468
Max Torque 458
Rick
You are right Rick, I always use SAE and correction factor 0 or 1. However others use different Correction Factors and it creates false readings when comparing run to run.
So whether someone wants uncorrected smoothing 5 or SAE 0, just compare that number to someone elses with the same factor or else you get apples to oranges.
JDM JIM likes to use STD, so just know when you compare to his runs, you use the same factoring.
hope that makes sense!
Old 02-21-2010
Another one of the guys there did explain that using a SAE correction factor generally lowers the output scores by 5-10 points, but that the main concern is always comparing graphs using the same methods of data output, whatever they may be. From my experience the crew at this shop has been good (http://blog.tunedbypsi.com/), and its a top notch place in terms of money invested and tools available. I just think that a 5:30pm run on a friday got the best of all of us. Even afterwards my dad was kickin himself for not remembering the trouble the first dyno-shop had in getting a good run (which I admit that first place was not the greatest). We hadn't factored in the time of removing the panels under the hood to access the computer wiring to get a good timing reference wire.
Yes, the 475hp upgrade will happen. One of my main reasonings outside of power increase is to be rid of what I believe to be some loud injector tick. The noise doesn't appear to be coming from the valve covers at all, and is timed with the injectors. I suppose it could be some piston slap but I haven't found a good location to listen for that. I just need to call JDM and see what their options are compared to Speedlabs and Brenspeed. I want a handheld tuner that this shop can upload their maps onto. I think they mentioned they are currently using a Diablosport tuner, and while they were looking at a different setup, they haven't had enough interest yet to warrant the investment and training into the new software. I'm sure JDM's tune is great, but every car is different, and furthermore I'd eventually like to run the Super shaker setup, and would like to dyno-tune it there.
In your opinions, do those numbers fall in line with what you'd expect a stock S/C Saleen of that year to generate?
Old 02-21-2010
AMS MIKE's Avatar
that definately could have something to do with it
for the 335i lift up the main engine cover on the passenger side corner facing the front of the car and underneath are Orange wires, put the shielded ignition pick up around ONE of those Orange wires
If you need any help on the 335i dyno proccess, just send me a PM.
As for Stock S281 S/C, Anything around 360HP-370HP is about right.
