Experience with I/C pump timer bypass? HELP!!!
I have been going round and round with this pump timer and bypass for awhile now. I replaced the pump timer itself, from saleen, it worked for a day then the pump stopped working. I have since installed the pump timer bypass, from saleen, still nothing. I assumed that since the pump stopped working it may actually have been the pump that finally gave out so I changed it and the replaced the old wires for the new that came with the new Bosch pump.
I`m by no means a mechanic but these directions, and task were very simple. Not sure what to do now. The pump still does not work and I have quadruple checked everything. I understand that Saleen has changed this entire system, is there a replacement system? Anyone have any ideas here? I`m stuck!! thanks |
Water Pump
Talk to Jim from JDM he has a few different options with as far as getting rid of the Timer completely or if you don't mind spending - a mezeire water pump. Worth a shot calling JDM or you can always try the old stand by Jess or Tony from Saleen they both know their stuff and maybe can help you diagnose the problem.
Jess and Tony both helped a great deal getting the parts to me. I have installed the parts and cant seem to get juice to the pump. Don`t know what else to check.
I/C Pump
It does sound like you might have a power problem. Call Jess or Tony on Monday I'm sure they will be able to run you through a diagnostic procedure. They know these cars in and out and are always very customer service friendly. Have Faith! It will get fixed!
I think I may have found the potential problem. I tested the green/white wire that supplies power to pump/timer and there is no power showing on my multi meter. The new question is, Does anyone know where I can access or reroute power to the pump? The green/white wire goes under the fuse box into the fender well between the fender liner to who knows where???
yea, still stuck |
There is a inline fuse for the heat exchanger water pump. I have seen these blow when the pump timer has problems. The in line fuse looks like the regular fuses for the Mustang, I think it is a yellow 20 amp.
Call Jim III at JDM , If I remember right its under the hood on the passanger side just infront of the fuse box ,down in the wires. Scott
You might find what you're looking for in this installation manual: http://saleenforums.soec.org/showthr...5633#post25633
Dave from Saleen has has me going in the direction of the smart junction box where the power originates.
Thanks for everyones help and guidance! |
If its under warrenty ok, but JDM sales a neat piece that bypasses the saleen one and you can also flip a swith while the car is off to run the heat exchanger water pump to cool down while waiting between runs at 1/4 mile.
