  #51
Old 10-11-2011
Meikol02's Avatar
Meikol02 Meikol02 is offline
Originally Posted by Jason @ 281m View Post
I'm quite positive it's not installed properly.
Well, then suggestions are in order!
Michael
'07-0449
  #52
Old 10-11-2011
Saleen S281 Saleen S281 is offline
Michael, you are showing all the same things that my car had, the shims should fix it, good luck!
  #53
Old 10-11-2011
crucianpilot's Avatar
crucianpilot crucianpilot is offline
Mine has the aluminum flywheel installed.
  #54
Old 10-11-2011
Anybody notice a little clutch smell when breaking in the new clutch? I have been easy on it and it seems that when I do a slow start easing out the clutch I get a whif of burnt clutch. Not bad, but never got it from stocker.
  #55
Old 10-11-2011
ExtrmStang#67's Avatar
ExtrmStang#67 ExtrmStang#67 is offline
I experience this.
  #56
Old 10-14-2011
Josh,
A small amount of smell is normal at first. But from your statement, it sounds like your not used to using a twin disc. Give me a call and ill walk you through "how to drive with a twin disc". Most people use them incorrectly.
  #57
Old 06-04-2012
Agent_177's Avatar
Agent_177 Agent_177 is offline
Sorry guys for bringing a thread back from the dead, but...
I am experiencing the samething as 06281E, Extrmstang#67, Tbar, and Crucianpilot.
I haven't fully broken it in yet and I have not been hard on it at all. I have not even rev'd it above 4500 RPM yet.
3rd and 4th between 1600 and 2000 RPM there is a rattle type sound like the car is about to stall. Anything above 2000 RPM never a noise.
Just wondering how all yours are working now? Still any issue's or all good now?
  #58
Old 06-04-2012
I still have the chatter below 2k rpm. Its been almost a year
  #59
Old 06-04-2012
DAVESIKE DAVESIKE is offline
Note to self. Don't buy a McLeod. Lol
281 RAD COVER.3.2 PULLEY
ROUSH BELT TENSIONER
3.73 MAX GRIP DIFF,JDM TUNE
GT500 FUEL SYSTEM,KOOKS LONG TUBES
HTO PLUGS,AFCO H/E,MGW SHIFTER
TECHCO INTAKE,ESCORT 9500CI
PIONEER AVH-P8400BH
CARDINALE ENGINEERING FRONT SPLITTER
UPR STRUT CAPS
FORGESTAR F14 MATTE BLACK RIMS
QTP ELECTRIC CUTOUTS
SALEEN FUEL DOOR,CHICANE TOWER BRACE
MESH HOOD INSERTS,281 LOWER MESH GRILLE
FAYS2 WATTS LINK,CAL PONY HOOD STRUTS
WMS STEALTH HOOD PINS
CUSTOM VALVE COVERS,281 COILPACK STICKERS
281 SUPERCHARGER DIPSTICK
  #60
Old 06-04-2012
Its a very minor chatter, its normal on twin disk clutches from what I've heard. It works really well, Ill test is holding power with the turbo soon.
  #61
Old 06-04-2012
I have taken the guys at The Mustang Shop in Auburn, Wa for a ride and asked them to focus on the vibrations and noise at low RPMs. One of the employees, and a driver of a twin disc himself, stated that his car with the same assembly has the same characteristics.
I have gotten used to it by managing the RPMs.
Concerning the chattering as you let the clutch out in 1st, I am still experiencing this when I get lazy and or the car is cold. I am going to start asking questions about shimming ßMY assumption) when I have the money set aside to do work on the car.
Now, my experience on the track is great, so great in fact that I did not have to worry about it while doing sessions and it was not something in the back of my head and or something I had to keep track of. As a general note, if you are in low RPMs on the track then your short shifting, but I can understand if someone wants to use low end torque and that may happen on only a few tracks and one turn on those tracks. I also experienced the clutch grabbing too well when making basic mistakes matching RPMs. Ultimately I am happy and looking forward to the fine-tuned shimming to solve the slight chatter.
I have to say that if and when the chattering happens it might make an audience wonder what is going on.
  #62
Old 06-04-2012
Stanghungry Stanghungry is offline
when I had my 06 saleen I had the mcleod clutch installed. The first 500 miles or so I felt like I had to learn all over again how to drive a clutch. After that very minor chatter going forward but I would still feel the chatter in reverse..
  #63
Old 06-04-2012
My issue is when going very slow in 2nd as I start to accelerate I here a little rattling sound for a second or two, till the speed increases. Dont know what it is.
  #64
Old 06-04-2012
06281E 06281E is offline
Everyone here is getting the same vibration in low RPM, supposedly it's just due to the dual clutch disk operation..
Davesike- What clutch are you running? See the problem is you have to pick the lesser of 2 evils, the McLeod is my second clutch on this Extreme, first one was a center force DFX with flywheel and it lasted a whopping 7k miles and had so much clutch pedal pressure i thought i needed a new knee when i was done with it. The McLeod is soft as butter and holds 1000hp, can't beat that even with a little vibration at low RPM. IMO still the best clutch for our cars out there, but i have heard there are new twin disk options on the market now.
  #65
Old 06-04-2012
Mine only does it in 2nd. Other than that I have no complaints. I find it lighter than the stock clutch.
  #66
Old 06-04-2012
tbrock's Avatar
tbrock tbrock is offline
My RST was noisy as well, and I also had a dragging issue on two seperate RST both with the McLeod FW. Switched it out several weeks back for a Mach 500 and the noise and dragging is gone. Pedal feel is a little heavier than stock, but I'll trade that any day for a properly functioning clutch. Three weeks the clutch is awesome and shifting is smooth as butter. My experience with the RST was not a good one. Good luck.
2007 Shelby GT, Saleen SC Stage 3 with 3.0 pulley,mosaleen tensioner sys. UCA,LCA,BMR A arm Brace, SVE Dark Stainless 18x10's, Nitto NT05's, MGW Shifter, Pypes LT's with off-road X pipe, Bassani Axle backs, FRP 3.73's,BMR Watts Link, Steeda shaft loop, JLT 110mm CAI, FRP valve Covers, Brenspeed tuned. 12.425@114.63 4800 feet on Nitto 555's. Latest dyno is 492hp/463tq.
  #67
Old 06-05-2012
i have a stock clutch..i dont see the reason to change it really till it fries tho!
PIONEER AVH-P8400BH
UPR STRUT CAPS
  #68
Old 06-05-2012
Meikol02's Avatar
I don't know how your stock is holding at that power level. I have similiar mechanical mods, and mine was slipping at the 3.4 and really went south with the 3.2.
I have the same experience at low RPM/ no load, or if I am lazy. The clutch is much better than the stock and only occasionaly hangs up (which I believe is a manufacturing issue like Tbrocks, just not as bad). Other than that I need a stickier belt as the clutch will grab like hell, and the belt will chirp if I am trying to shift it hard and fast.
Michael
'07-0449
  #69
Old 06-05-2012
Agent_177's Avatar
Well this is all not good news. Its more annoying then anything. Drive by and all you hear is chatter. WTF! lol
I hope mine goes away after the break in period. If not. Something has to be done. Because city driving, I don't wanna be rev'ing high nor do I want people to hear the chatter.
  #70
Old 06-05-2012
maybe original owner put another in but i never did and it holds fine..
PIONEER AVH-P8400BH
UPR STRUT CAPS
  #71
Old 06-05-2012
It also depends a lot on how you drive the car.. Also nothing lasts with over 500hp so you can bet that a new clutch is always in our futures.lol
