Who has the highest hp/tq numbers? - Saleen Series I-IV
Been thinking....who has the highest hp/tq numbers with a STOCK Saleen Series I-IV SC (not Series V)?
I know the Berylium Beast is running 500rwhp....but that's w/ a Series V....Anyone else close to that with a Series I-IV? There has been a lot of talk lately about getting into the motors and upgrading but most peopel change out the SC by then as well. I know that the highest your gonna see non-forged is roughly 415rwhp. But who has a forged bottom end running the STOCK non-extreme Saleen SC? * I DO NOT want your numbers for an aftermarket SC or 4v motor (sorry CodeRedSaleen LOL). I'm just not going that route at all, want to stay with a stock looking engine.
Very interesting thread.. I'll post my numbers once I finish installing the last parts I have to install and get in tuned. :) I'm aiming for anything higher than 435rwhp.
subscribing. I should get mine dyno'ed.
380hp 390 torque on my dynojet trapp 116mph it made power
00gt 10k on the clock saleen s4 blower and full saleen body kit. 2.76 upper, 42's , 90mm maf, 75mm tb, focus pump. high flow cats, stock gt exhaust, 31splines and 373's. best et without body kit was 11.9 at 116mph on et streets. 1.60 sixty foot. way more to come out of this combo sct tuned by me. |
Last time at the track I trapped 108-110 for 9 passes. lol. It was a slow night.
14.0 is the best I could do on the Pirelli's. |
http://50mustangsuperfords.automotiv...ang/index.html
"James contracted VT Engines to construct a fresh short-block centered around a forged eight-bolt Cobra crank, 0.020-over forged Diamond pistons with a 19cc dish and Manley forged H-beam rods. Displacing 283 ci and with 9.1:1 compression, VT calls it the GT Sportsman. Modular Powerhouse custom blower cams and Comp Cams beehive springs are fitted to the stock heads. Since everything was apart anyway, a SPEC clutch and billet-steel SFI-approved flywheel were added to front the reworked Tremec 3650 tranny. Installation and tuning were handled by Pandes Performance in Westland, Michigan. Why build all this strength? Because James decided to up the boost (13 psi) with a Chicane 66mm blower pulley and a custom Nitrous Express laughing-gas system. He also opted for an NX N-tercooler to chill the boost breath. On a typically conservative Mustang dyno, the results are 477 rwhp without the nitrous and 567 rwhp with it. The tough short-block was likely a wise investment."
Series II SC w/66mm pulley Stg2 Cams .020 over bore (stock compression?) 75mm TB SCT MAF Long Tubes w/H-pipe SCT Tune The stock compression ratio was 9.1:1 from 99 to 01 and they upped it to 9.4:1 in 2002 to 2004 and now the 2005 models have a 9.8:1 CR.
391rwhp/387Tq with a 2.8 pulley and stage2 heads and comp cams.
Im putting down 406rwhp/439tq
"04" #110 S281 SC Convert. Mods: Chicane Intercooler,Chicane SS Braided Line Kit,LFP Heat Exchanger,LFP Intercooler Reservior,FR 3.73 gears,90mm MAF,42lb Injectors,Accufab 75mm,Series 6 Saleen Extreme Pulley 2.875,Mosaleen Idler Pulley,NGK TR6 Plugs @.035,Tunable Induction CAI,Kooks Longtube Headers,Kooks H-Pipe With Hi Flow Cats,12% Overdrive Crank Pulley,04 Cobra Tank And Fuel Pump,FR Aluminum Driveshaft,MM Full Length Subframe Connectors JDM Dyno Tune 410-RWHP 436-RWTQ |
Those are so real good numbers there!!
'99 MUSTANG SALEEN S-351 #37 "FASLEEN" '99 MUSTANG SALEEN S-281SC #201 "SLOLEEN" '99 MUSTANG SALEEN/COBRA S-281 #320 |
your numbers STD or SAE?
Same setup I'm running....except I do not have the IW Overdrive pulley or LFP H/E (yet ;) ) Other than that it is the same. What boost levels and IAT's re you seeing? I'd love to see a dyno graph! I'd be happy to see over 400rwhp....anything more than what you got I'm guessing is gonna need a forged bottom end! thanks!
I dont know if the numbers are STD or SAE my IAT's around 130 or so heres a copy of my dyno sheet
"04" #110 S281 SC Convert. Mods: Chicane Intercooler,Chicane SS Braided Line Kit,LFP Heat Exchanger,LFP Intercooler Reservior,FR 3.73 gears,90mm MAF,42lb Injectors,Accufab 75mm,Series 6 Saleen Extreme Pulley 2.875,Mosaleen Idler Pulley,NGK TR6 Plugs @.035,Tunable Induction CAI,Kooks Longtube Headers,Kooks H-Pipe With Hi Flow Cats,12% Overdrive Crank Pulley,04 Cobra Tank And Fuel Pump,FR Aluminum Driveshaft,MM Full Length Subframe Connectors JDM Dyno Tune 410-RWHP 436-RWTQ Last edited by countum; 09-12-2011 at 08:23 PM. |
Im guessing 14lbs with the Overdrive pulley and the SC pulley....?
I have about the same mods at countum, minus the crank pulley, long tubes, spark plugs. I just added the Chicane I/C, LFP heat exchanger, LFP supertank, Bosch Pump, and a 66mm S/C pulley. Can't wait to get a tune and see if I can do better than 320/340!
http://www.mustang50magazine.com/fea...ang/index.html
http://www.domesticdriver.com/issues...ember-2007.pdf Last edited by SALEENJAMES; 09-13-2011 at 08:26 AM. |
I talked with Fastlane Motorsports yesterday about engine upgrades to handle more power....these are the notes:
1. The Trick FLow heads have not produced very much gain on the motors they have tested. These heads were developed fo rthe BOSS block with the larger 3.7 bore. The boss block adds quite a bit of money...even more for the AL version! 2. For the price, the port & polished stock heads with larger valves will be better. 3. They do not recommend stroking the motor due to longevity reasons. 4. They recommended me to have my stock block bored .030 over (284ci) stock compression ratio and do a cobra crank and forged rod/pistons. Get the Stock heads ported and due "Twin-Screw" stg2 comp blower cams. with these upgrades I coudl push more boost with a lower pulley (Heat soak dependent) I should get around 450 rwhp. (from reading Jame's mods/numbers above that is about right) All for $10,000 out the door w/labor & tax....NOT worth the cost in my opinion! I may stay just like she is and just add the LFP H/E and be done with it!?
'03 SC Coupe (1 of 2) 380hp / 400tq @ 12lbs boost 18x10" rear wheel option 13" Saleen Brakes ◄ Chicane Intercooler ◄ 2.875" VI Xtreme Pulley ◄ 4" polished CAI 75mm TB ◄ Bassani Exhaust (Mid Length Headers, X-Pipe, Mufflers) ◄ FRPP 3.73 gears 90mm MAF/42lb Inj ◄ Ford GT Fuel Pump ◄ Rear LCA's ◄ Subframe Connectors + more! Last edited by SonicBlue; 09-13-2011 at 09:03 AM. |
What?!?! Come on. Wow, 15 grand more and you can have another Saleen. And an E car for that matter.
I called JDM today and talked to them....
They recommend doing the 10% Overdrive crank pulley ($399) and upgrading the H/E ($299) to cover the heat soak issue that running more boost might cause. They said that I'll be at about the highest I can go with the stock bottom end at that point. Adding Cams would be good as well but is gonna be more $$$. Port and Polishing the heads will cause the boost to go down cause the better flow but that's not a bad thing, just gonna be pushing it to the limits on hp/tq #'s at that point on the stock rods/pistons. So looks like I might be all done on perf mods after I order the IW crank pulley next week.
But "countum" should have the definitive answer cause he is already running the same setup I'm going for.
what pulley is this? |
I get up to 14lbs of boost
does your Mosaleen Idler Pulley take away any power or boost? |
LOL, darn I can't play in this thread since I don't have a series I-IV Saleen blower.
443RWHP and 392RWTQ on my 99 Saleen with a Series IV Swap. :D
Wow, I have never seen over 10 psi on mine.
PJ with SuperShaker @ 8lbs boost = 483 RWHP / 464RWTQ.
Has the opporunity of taking the boost much higher.
'07 Saleen / Parnelli Jones 302SC Super Shaker PJ #39 (RW 483HP / 464TQ) '05 Thunderbird - Inca Gold 1 of 82 '03 Thunderbird - Torch Red '13 BOSS 302 - School Bus Yellow with Trackey Option & Seat Delete Last edited by Bruce; 11-18-2011 at 12:16 PM. |
Bruce, We'll have to line it up...see what the PJ can do!!
2004 S281 #50 - 492 rwhp, 494 rwtq (Sold) 1997 Viper GTS #123 (Sold) 1996 S281 #63 (Sold) 2000 S281 #108 (Sold) 1993 Cobra #2302 (Sold) |
