Old 07-05-2020
calbear calbear is offline
Question Q: Tire Pressure 17" Sterns? - Customized Alignment Specs
What tire pressures are people running on their front and rear Sterns? Using Nitrogen vs traditional air?
BFG Comp T/As, Max PSI=51, 17 x 8 fronts and 17 x 9 rear? I've used 44 PSI in fronts and 46 PSI in rears with pretty even tire wear. (Custom front alignment where I'm using negative 1.5 degree camber. With the stock Saleen spec -0.75, the outer tire edges seemed to wear out first.
My Sterns tend to slowly leak air- over 3 months of non-use, the rears dropped down to 18 PSI.
87-0116 owner
former Saleen Autosport Anaheim Hills employee
89 Saleen Mustang and SSC production line
Specialist: body work assembly, decals, detailing
Old 07-08-2020
joemasone joemasone is offline
TTT. Would like to know what pressure everyone’s running as well.. thanks
Old 07-08-2020
delvin delvin is offline
Fill them to what the door tag says.
Old 07-09-2020
What do the tire side walls say?
