  #51
Old 01-17-2011
Coderedsaleen Coderedsaleen is offline
Originally Posted by OxfordS281 View Post
What gauges are in the pod? Also what gauge is on the steering column? Is the car running in the picture because two the gauges look out of sync?
That pic was taken just after I did the engine conversion. The gauges in the pod are the Saleen H2O temp and boost. They were not hooked up at the time. I have a Saleen fuel pressure gauge on the steering column, that to was not hooked up.
Thanks for noticing though, good eye!
  #52
Old 01-17-2011
Originally Posted by tennesseemustangperformance View Post
Yes I did, one of the first things I noticed. Does the airbag work? How did you adapt the hex wheel to fit the spline drive of the column. I was wanting to do this to my '98. Great work!!!
Yes the airbags does work, well it is hooked up...
With a little cutting and welding it will fit. I took my old wheel and had the brass insert welded into the new one after cutting the long hex stem off. I wish I would have taken pics.
  #53
Old 01-17-2011
OxfordS281 OxfordS281 is offline
sounds good was just curious, after asking if the gauges worked i was interested in which ones they were. how did you get the fuel pressure to work? did you buy one off ebay? i see them there all the time but they dont come with the pieces to make them work.
  #54
Old 01-18-2011
Yes I bought the fuel pressure gauge off eBay, but when I bought it, it came with a bag of stuff since the guy didn't know what went with it.
It is easy to hook up though, and you can get the parts from Autometer.
  #55
Old 01-31-2011
03SaleenSC 03SaleenSC is offline
Wow you have a ton of work into that car.
Looks amazing by the way....
  #56
Old 01-31-2011
Thanks! Yeah it has been a project since day one when I ordered it from Ford.
  #57
Old 02-01-2011
To those that are interested in doing a 32V conversion here this is what I did and your results may very. This is not complete listing because your mods, parts and methods of installation may differ from mine.
This conversion is a 01 S/C 2V engine w/ T45 transmission to a 03 S/C 4V Cobra engine w/ T56 transmission.
1. 03 Cobra engine
2. T56 transmission
3. 03 Cobra drive shaft w/ rear flange changed
4. T56 transmission mount
5. All OEM wiring harnesses and PCM
6. Lengthen wires on certain sensors
7. FRPP injector adapters
8. Lengthen wire on transmission
9. 03 Cobra hoses for cooling w/ thermostat housing
10. Plumb the inter-cooler with existing Saleen pump and reservoir
11. 03 Cobra or GT Super Car fuel pumps.
12. Wire upgrade to the fuel pumps.
13. 03 Cobra fuel tank
14. Larger air filter
15. Change polarity on COP and lengthen wires
16. DYNO TUNE (Yes you can put a 03 Cobra tune on a 2V PCM)
This list is not complete because I am probably missing some things since it was last year when I did this.
If you have any other questions just ask I might be able to help you out.
  #58
Old 02-01-2011
Here is a pic of the wire upgrade I did. I wired it straight from the battery to a relay to ensure the FPDM gets a constant voltage of at least 13.5 or higher. Notice I also included another set of wires to the pumps to prevent voltage drop along the wires. Lethal Performance has a kit made up for this but you can make it yourself alot cheaper.
Oh and not pictured is the inertia switch wiring, instead of the ground going to the chassis (Blue wire on relay) it now runs though the inertia switch to ground out the pumps like OEM. On a Cobra it is wired back to the PCM with white wires.
Inside of trunk driver side:
Under passenger kick panel:
Ford Racing injector adapters (Black piece between the wire and injector).
  #59
Old 02-01-2011
Some one asked about my Saleen outline letters for the rear facia, here is a better pic:
  #60
Old 02-05-2011
Did you see that go by? Man that is one sharp car. LOL!!!!!
  #61
Old 02-13-2011
Here are a couple of pics of Steve signing my car at the June 19th, 2010 Bob Bell Ford show in Glen Burnie, MD:
would love to see this in 2011! I also see you have the mach1000 system in the car! very nice i love mine.
  #62
Old 02-13-2011
Greg Wackett Greg Wackett is offline
Inactive Account
Tim,
Will you be attending Marks open house year? We has a go cart race planned for Friday night. I will be post a more details in a couple of weeks. We are still working out some of the details.
Greg
Greg Wackett
  #63
Old 02-13-2011
See what in 2011? Yes I like my Mach1000 also (installed myself), not an option for the 2001 model.
  #64
Old 02-13-2011
Originally Posted by Greg Wackett View Post
Tim,
Greg
Yes I will be there at the open house. I had a great time at the last one. Do you have the date in July again? Oh nevermind I see it listed in your sig. LOL!!
  #65
Old 02-13-2011
well done on the self install. oh id love to see all the saleens in glen burnie this year, especially if steve saleen made an apperance
  #66
Old 02-13-2011
Yeah if Steve shows up again I will take another ride up there to show again.
  #67
Old 02-13-2011
Here is my new project car and yes it has the SMS 302 decals on it. It just starts with one addition then ...
  #68
Old 02-14-2011
If you remove the 5.0 badges. Swap the grill and taillight panels, you'd have something really close to the new SMS 302 White Label. A new model at or under 40K.
  #69
Old 02-14-2011
Inactive Account
2011 Events not to miss
-Performance Autosport open house July 9th 2011
Greg Wackett
  #70
Old 02-14-2011
Inactive Account
Keep an eye on the site Jim will post updates on where Steve will be over the summer. Sturgis is confirmed Labor day
Greg Wackett
  #71
Old 04-17-2011
tennesseemustangperformance tennesseemustangperformance is offline
So I take it the wheel is aluminum and not magnesium then... good to know.
Which brass insert are you talking about, by the way? I scored a premium 2011 wheel earlier tonight, and would love to install it in my 1998. Did you wire up the switches as well?
  #72
Old 04-19-2011
The brass insert is in the old 99-04 wheel, I had it cut out of the an old one then the new wheel was modded to accept the brass insert. Yes the wires are wired up for the cruise.
  #73
Old 04-19-2011
00_ExtrmRnbw 00_ExtrmRnbw is offline
My first time seeing your pictures and what a beautiful car you have there!!
Johnny
'00 Saleen SC Spdstr, Extreme Rainbow #387
'02 Saleen Extreme Coupe, Extreme Rainbow #019
'03 Saleen SA-20 Anniversary Speedster #03
  #74
Old 04-19-2011
Thanks for the compliment!!
  #75
Old 04-19-2011
Very cool, thanks for the info! I can't wait to install my 2011 wheel soon, have been wanting to do this wheel swap since the 2005 came out.
  #76
Old 05-15-2011
Default Installation of my new 335/30/18R tires.
Here are some pics of my new tires, to stay true to the Saleen styling I put on some Perilli PZero Rosso.
Front are 265/35/18R on 18X9 Saleen rim.
Rear are 335/30/18R on a 18X11 Saleen rim.
Hard to see the tape measure but the tire is 13" wide.
  #77
Old 05-15-2011
OneQwkStang's Avatar
OneQwkStang OneQwkStang is offline
Real or not, it sure looks sweet. I'd be interested in a trunk mat too.
  #78
Old 05-16-2011
Josh2J's Avatar
Josh2J Josh2J is offline
what a ride... great thread! awesome work!
2002 Saleen S281 # 461
http://i788.photobucket.com/albums/y...hoot035SIG.jpg
V3 Si-Trim Polished Vortech Supercharger, Anderson Blower Cams, Devil's Own Meth Kit, 60lb Injectors, SVT Fuel Pump, NGK Plugs, Diablos MAFia, SCT Chip,
4" AFM Powerpipe, 3:90 Rear Gear, Bassani Headers and O/R X-pipe, BFGoodrich KDW's, H&R SS Springs
DynoJet Tune by Modern Muscle, 460rwh/415 torq @12 psi
  #79
Old 05-16-2011
Thanks for all the great compliments! Send me a PM if you are interested in getting a decklid mat.
  #80
Old 05-16-2011
Rayder_K Rayder_K is offline
Default Your Doing The Right Stuff Bro
CoderedSaleen, huh, I think I seen your youtube videos or something, sounds familiar. But hey, those seats covers for saleen, do you mind tell me where you got that done?
  #81
Old 05-16-2011
Don't have any videos on Youtube that I know of. The seats are from a 03 Cobra but the headrests were done years ago and don't remember where I got them from.
  #82
Old 05-22-2011
Here is a pic from behind:
  #83
Old 05-22-2011
  #84
Old 05-22-2011
  #85
Old 05-24-2011
i love the center exhaust with 3 piece wing. if i would of had more time i would of bought one to go with my 3 piece. instead i went with the E-Wing. i do like the custom graphic you made for shows i assume. very sharp.
  #86
Old 06-10-2011
Yes I made that spec card to be used at car shows. People are always asking me questions about it.
  #87
Old 06-18-2011
  #88
Old 07-03-2011
LeftLane_94's Avatar
LeftLane_94 LeftLane_94 is offline
Really great car man. Idk if you still have trunk mats left, but I may be needing one of these from you. I need a new steering wheel in the worst way... was the install hard??
2003 S281-- 03-0094 Running Strong
1996 S281-- 96-347 Triple Black Vert Automatic--TOTALED
2006 GT--Traded
2001 GT--TOTALED
2001 V6--Sold
  #89
Old 07-03-2011
Thanks for the compliments! The 05 steering wheel was easy if you can do some cutting and welding, LOL!
PM sent about the trunk mats.
  #90
Old 08-27-2011
Saleen S281 Saleen S281 is offline
Awesome ride! I want to do something similar with my 06 s281, with the 5.4 gt500 engine and a Tremec 6spd. Good luck with the 5.0!
  #91
Old 08-31-2011
look up the fr500 wheel or a 10th anniversary wheel, both good replacements
  #92
Old 10-09-2011
  #93
Old 11-05-2011
Wild Wheels Weekend 22nd-23rd Oct. at the Va Bch Convention Center 2011
  #94
Old 11-05-2011
  #95
Old 11-06-2011
dont get me wrong, im sure those seats are comfortable, i hear it all the time from cobra owners, but MAN those seats look so boring in your saleen. the ones that came in the 03/04 look more sportier than them. If i were you id get some custom recaros or something that stands out more, those i will admit they look oem, i just feel the gray suede is so blan.
  #96
Old 11-06-2011
Thanks for your thoughts and that is just what they are. I like my seats that is why I put them in there. If I wanted to go with other peoples opinions I would post a thread and asked. I made the car the way I wanted it. Other Cobra owners can change their seats to what ever they want to so they are not "boring or bland", but I will keep mine. To understand your highlighted comment in the above, those seats are from a 03/04 Cobra just in case you didn't know that.
Oh by the way, White is such a boring color. You need to change it to something more stylish like Laser Red, Sonic Blue, Screaming Yellow, Torch Red, or even black. White is the absents of color, just like your comments.
But then again you are entitled to your opinions, Thanks again!!!!
  #97
Old 11-06-2011
Oh by the way, White is such a boring color. You need to change it to something more stylish like Laser Red, Sonic Blue, Screaming Yellow, Touch Red, or even black. White is the absents of color, just like your comments.
Well since this is a saleen forum, and it is the 99-04 section, i was reffering to the 03/04 Saleen seating, the stock ford seats that saleen recovered. Maybe its just because of the headrest, but i like those seats over yours. I will admit the black on black 03/04 cobra seats look sick, as well as the 2003 cobra 10th anniversay seats. I've never heard of "touch red" what year did they make that color?
If you dont wanna hear comments on your car then why did you create your own thread? Everytime someone talks about supercharging their 2V saleen, or increasing horsepower, you post your engine and tell them "no problems here with my motor, or "maybe you should do what i did"... acting like no one has seen your car before, and offering them NO HELP to their actual issue.
BTW: you are welcome.
  #98
Old 11-06-2011
In the above you need to do more research because Saleen did not recover OEM seats. The seats were either left OEM or Recaro wrapped in Saleen covers and offered in other years. You need to spell check what you write before you talk about someone else's.
I welcome all comments positive and negative. If you don't like how I respond to the comments then don't post any. I don't see you making a thread or posting anything about your car, what you did to it, pics, or anything. You probably don't know how to do anything on it anyways.
I have helped out alot of people on here, more then you know. When I talk about my conversion I am just giving a option that is available and how to do it.
Also I am not going to get into a pi$$ing contest on here with you since it is a waste of my time. Get over it because this is the last time I will respond to your comments.
  #99
Old 11-07-2011
Codered love your car. A lot of subtle touches, or would that be torches...lol, without going overboard. Classy. I for one have had tons of help from Codered, amongst others, and his help has been nothing short of spot on. Thanks again...
  #100
Old 11-07-2011
Werecow - To funny! Your welcome anytime!
