Go Back   The Saleen Forums at soec.org > Saleen Enthusiast Forums > Saleen Photo Galleries and Videos
Saleen Photo Galleries and Videos Photos and videos from events, shows, gatherings, race days, or other memories to share digitally.
Old 09-17-2013
saleen777's Avatar
saleen777 saleen777 is offline
Default Saleen on the Dyno
I took my 01 to get a tune. Slapped her on the dyno, here are the results...
http://youtu.be/OfRFkPK4yZA
Old 09-18-2013
Werecow Werecow is offline
Nice... how bad was the original tune?
Old 09-18-2013
Agent_177's Avatar
Agent_177 Agent_177 is offline
Lidio is awesome! Just always busy. lol
Great numbers. What's been done to the saleen?
Old 09-18-2013
saleen777's Avatar
I picked up 30hp with the tune. first pull was 285 RWHP.
Old 09-18-2013
saleen777's Avatar
It's got a pulley, cold air, and exhaust. Next step is long tubes and cams.
Old 09-22-2013
Snakecharmer383 Snakecharmer383 is offline
Nice pick up...makes me want a tune!
Old 10-03-2013
saleen777's Avatar
UPDATE: my new Mosaleen pulley came in. :-) I'm hoping to have time to put it on this weekend. Ill let you all know how it effects the car.
Old 10-26-2013
saleen777's Avatar
Ok, the Mosaleen pulley is totally worth it!!! Went from 9 psi of boost to 12!
Old 10-27-2013
Not sure how you got more boost by just adding the Mosaleen pulley. All it did for me was tighten up the belt and move the actual belt away from my upper radiator hose. I'm guessing you changed the actual S/C pulley at the same time?
Old 10-27-2013
Maybe his belt was slipping and not letting it build boost??
Old 10-28-2013
Definitely possible
Old 01-20-2014
saleen777's Avatar
That was exactly the problem. Not anymore!
Old 01-20-2014
mosaleen's Avatar
mosaleen mosaleen is offline
Saleen 777 , glad it worked so great on your Saleen, but you might want to check your air/fuel ratio if you tuned it with the loose belt if your tuner didn't leave some room on the air/fuel ratio.
Snakecharmer. I didn't ever hear back from you so I thought it did well for you to. Did you not feel the boost come in sooner and increase 1/2 to 1 lbs.? I give a money back guaranty if you are not happy with the product.
3:73 gears, Watts link Gen II
Old 01-20-2014
saleenster's Avatar
saleenster saleenster is offline
Love the hood. Those are good numbers from a series I or II blower.
95-104 R code
03-15 E
Old 01-25-2014
Mosaleen: I'm happy with it, no issue there. I just didn't see any noticeable difference. The fact that it moves it away from the upper rad. hose is enough for me. I may have gained boost and it may come in sooner but I just simply didn't notice it or feel it driving.
Old 01-25-2014
mosaleen's Avatar
Ah I see, it does depend on how bad each individuals belt is slipping. The smaller S/C pulley tends to slip more also.
I did a test on a 2002 Saleen with H-pipe, CAI & K&N filter, 66mm S/C pulley, SCT tuner. We put a 4061120 gatorback belt on brand new, he could feel a difference from his old belt. Ok I had him drive around for 1000 miles , then we put Mosaleen back on it, he said it was about the same difference back when we put the new belt on. What happens is a new belt will stretch out 3/4 to 1 inch. and lets it start slipping on S/C pulley.
