TECH HELP NEEDED Car won't charge
I've got a 89 saleen and i've been having alot of work done to it. It is finally done however the car won't charge. The alternator I had in it was an overhauled 130 amp which apparently went bad. So, put another one in, that was bad. Put another in, this one works(confirmed on bench) but it still won't charge in the car. Checked all associated chassis wiring, all checked good. Tried eliminated the chassis harness all together and still no joy. So, decided to try a one wire alternator. Same problem. Has anyone come across something like this and do you have any suggestions. I NEED HELP. The only other thing I can think of is Electronic Specialists and I don't have the money for that NOW. Please help
