Old 09-06-2010
FATHERFORD FATHERFORD is offline
Default Dynoed my S331 S/C - Graph Image
Went to PSI Motorsports in Webster Texas last Friday and got my truck tuned for the 60lb injectors.
Ended up with 453rwhp on a conservative tune with 100+ degrees in the shop in very high humidity... Here in the winter months I should easily be putting down around 500rwhp.
The part throttle tune still needs to be worked on. I'm hoping I can get JDM to work with Patrick at PSI to give some help on the tune.
With the mosaleen idler I saw an increase of about 2psi.
Old 09-06-2010
kidlightning5 kidlightning5 is offline
Do you have any mods? If so what are they?
Old 09-06-2010
Good explanation here.
http://saleenforums.soec.org/showthread.php?t=8185
Old 09-07-2010
mosaleen's Avatar
mosaleen mosaleen is offline
Glad you got to get to a dyno, fantastic no's and wow 2lbs of boost gain.
Did you get hp/tq gains from bolting up the mosaleen system?
Have fun with all that hp/tq
Scott
3:73 gears, Watts link Gen II
Old 09-07-2010
Scott
Hard to say what my gains where when bolting up your system. Unfortunately I was on a different dyno, different time of the year, and I had added other mods to the truck(long tube headers and resonators instead of cats).
So if anything my boost should have went down from the additional mods, the fact it went up explains how much belt slip I had with the 2.87 pulley.
I have a feeling there is more in the tune for peak numbers...
Old 09-12-2010
