04 Saleen 281sc
Hi- I just picked up a 2004 Saleen 281sc Conv. I'm a new member to your site. The saleen is stock. I'm starting to upgrade it and made a list/plan. I just bought a new pulley from pulley boys (2.9) and a sc dipstick. Could someone please tell me what size the stock pulley is before I make the change. Thanx
Welcome to The Saleen Forums @ SOEC Muzzy!
I believe the stock Saleen Series IV pulley is a 3.12. Once again, welcome to the forums and we wish you the best with your new purchase! |
Thanx- I have two old mopars 69 Dart and 68 Charger and I'm having more fun with this saleen than the mopars. I can't believe how a little change like a pulley gives the car more HP.
did you ever install the pulley? what boost level did the 2.9 achieve? im looking to run between 10-12lbs, anyone know what size i need?
Hey sycho...you ever get over to the "mainland?" I'm over near baltimore. We should cruise sometime.....
i plan to do the ford gt pump, and yeah, im in baltimore often, family is there. have to hook up sometime.
I did change the pully (2.9). The car is in storage until spring so I just don't know yet but it seems to idle just fine. Also the belt is still tight. I think I made the right choice with the 2.9 pully. I talked to the guys at pully boys and said I see about a 2-2.5 pound gain... we will see soon!
