Old 02-03-2014
02saleen353 02saleen353 is offline
Default Seeking part: Intake plenum - Series II
Hey guys so I've been having some issues with my 02 saleen and finally took it to a shop and they said its a vacuum leak.
They told me that the intake plenum(connects from the TB to the back of the supercharger) is cracked and contacted saleen who told them basically that they didn't supply them anymore.
I was just wondering if anyone knows where I could either purchase a used one or an aftermarket version that would work?
Any help is appreciated!
it looks like this(black piece behind sc+TB):
Old 02-03-2014
Can we weld the inlet and crack? Is this an option?
Old 02-03-2014
That is an option if that would fix the issue haha. Would it matter where it is cracked? I'm not sure at the moment where exactly it is cracked, I'll be able to find out tomorrow.
If that is possible, is it a do at home job?
Old 02-04-2014
Do you typically weld aluminum at home?
Old 02-04-2014
The piece is actually plastic, not aluminum. I wouldn't even consider it if it was aluminum.
Old 02-04-2014
eviligloo eviligloo is offline
Yeah unfortunately the majority of them are plastic. I thought I've seen a couple of them that were metal (maybe the early ones were for the series 1).
Best of luck finding one but it's going to be really difficult. If you have a series II supercharger you need that piece to make it work so it will be in short supply. Even people that upgrade to a KB would sell those as part of the kit when they get rid of the series II. Look for someone that has changed out the entire intake that would be willing to part with it.
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
LFP Heat Exchanger and Supertank
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Maximum Motorsports LCA's, Subframes, Torque Arm, Panhard Bar, Steering Shaft, Front Control Arms and Aluminum Rack Bushings
MM Coilover kit with caster camber plates
Old 02-04-2014
Series II.
Old 02-04-2014
I actually did find one that someone on another forum had replaced so I think I'm just going to get that one from him, its plastic as well. I think the one I have is the same as the one on the right in the 2nd picture which I believe is plastic, not 100% sure though.
In any case I'm gonna snag this one since they're not easy to come by.
Thanks for everybody's input!
Old 02-04-2014
I think it is interesting how some elbows appear to have a raised SALEEN marking while others do not.
Old 02-04-2014
Yes yours looks like the one on the right. The one on the left is the tork tech intake which is metal.
My old one is plastic and is sitting in the garage. It has the raised saleen lettering.
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
Chicane Intercooler
42lb injectors
90mm MAF
Old 02-04-2014
Yeah all of the plastic ones I've seen have had the "Saleen" raised on it.
You wouldn't be looking to get rid of that piece would you? The other one I was going to get has the TB cable mount hole stripped out just like my current one.
Old 02-05-2014
yellowpony281's Avatar
yellowpony281 yellowpony281 is offline
I'd recommend upgrading to the Tork Tech. I have one on my Series II with one of their oval single blade throttle bodies. Lots more air available = alot more power too!
Old 02-05-2014
How much was it and what did you have to do to get it to fit?
Old 02-06-2014
YellowPony: You have the whole Tork Tech System right? Just using their inlet requires a bit of fire wall massaging.
Old 02-07-2014
I bought it as part of a retrofit kit from someone else here on the boards. you can get parts and prices from Tork Tech. Pricing was about 4 years ago so I'm sure they have changed since then. http://www.torktech.com/mp112-interc...tuner-kit.html The plenum bolted right to the back of the Saleen series II blower. Did an EGR delete because I didn't want to deal with refabbing the stock EGR tube. Used a 03/04 Cobra throttle cable to replace the stock throttle cable. Rerouted some of the vacuum lines by pulling vacuum source through EGR delete plate, but beyond that not much more refabbing.
Old 02-07-2014
Not in this case...I do have the Tork Tech plenum and 63mm x 130mm oval throttle body mated to Series II Saleen (Eaton M90). This is the same plenum and TB used in the Eaton M112 4V Cobra blower to 2V swap kit. Because it went on a M90 blower I did not have to do the firewall clearance mods you have to do with M112 mod kit because we moved the vacuum tree to the EGR delete plate as my vacuum source.
Old 02-08-2014
That looks great yellowpony, I've got a similar intake from Tuneable Induction. Did you buy the piece that connects the tb to the maf or have it made?
Also I'm not sure if you've seen evil's build or not but he did have to cut into his firewall to get the intake to fit for some reason. Thats pretty much the only reason I haven't bought the tork tech intake yet.
I did take off the intake plenum and it turns out the gasket was blown out -_-, not cracked like the shop said they thought it was. But I guess I can't complain. A gasket is a little less than a the tork tech
Old 02-08-2014
Looks like they might have moved the vacuum line connections on your version. They mentione that they were going to do this when I spoke to them. The reason I didn't go this route was the EGR thing... being in CA I couldn't delete it.
Old 02-08-2014
That is a BBK 03/04 CAI tube.
Old 02-08-2014
No, this is the version with the ports on the back of the elbow that would have required firewall mods. We just epoxied those ports closed and moved the vac tree off the EGR port. Not really legal in Jersey either, but since this car is registered "collectable" in Jersey I have self inspection.
Old 02-09-2014
Cool... looks sweet and I know the power is much better as these blowers love air. Evil gave me a ride in his car and I couldn't believe how much that thing pulled... Made my SC feel like it was sucking through a straw.
Old 08-05-2015
daniel daniel is offline
hey yellow pony do or can you post some pictures of the vacuum tree moved to the egr delete port and how you did that i am thinking about going this same route and really do not want to cut into my car. what kind of epoxy did you use did you cut them off flush and then epoxy or just fill the tubes.
Old 10-24-2018
OxfordS281 OxfordS281 is offline
I have a few spare inlets. I may see about getting them made, in either metal or carbon fiber.
1996 #222 1 of 21 in Moonlight Blue 1 of 8 with exact options
3:55's F-Leather 2 Point Chassis Brace
1999 #259 3:08's Chrome wheels, Supercharged, Floormats.
Old 10-28-2018
01_529 01_529 is offline
Does anyone have a series II plenum or know of someone who has one that they are willing to sell ? Thanks in advance ! JB
Old 10-28-2018
I do
Sent from my iPhone using Tapatalk
Old 10-29-2018
Sweet, let me know when one is available, I am ready to purchase and install as of last week, the whistle I am hearing and poor gas mileage is killing me. Thanks again OxfordS281 !
Old 11-05-2018
Pm sent
Old 11-28-2018
TrueBlue772SC TrueBlue772SC is offline
Default Intake elbow
I have a aluminum one I took off and replaced with a TorkTec
Old 11-28-2018
I have a aluminum one I took off and replaced with a TorkTech
Old 12-30-2019
Greg Moldenhauer Greg Moldenhauer is offline
Default Super charger intake
Need the intake plenum for an '01 supercharger - mine is cracked.
Old 12-30-2019
I have 2
Old 12-30-2019
Default Saleen
Aluminum or plastic?
How much?
Greg
Old 02-06-2020
Vlocity25 Vlocity25 is offline
I am looking for an intake plenum as well if anyone is selling one please message me. Plastic or aluminum. Thank you
Old 05-03-2020
Xtreme281SC's Avatar
Xtreme281SC Xtreme281SC is offline
Also looking for a Series II intake plenum elbow in aluminum.
Old 06-24-2020
Sgravett Sgravett is offline
Default Series ll intake plenum
I am in need of an intake plenum. Does anyone know where I could get one, or does anyone have one I could purchase from them? I am not able to drive my car until I find a fix for this problem. Thanks for your help.
