Old 08-17-2012
emba129's Avatar
emba129 emba129 is offline
Default Squeaky Brakes on PJ
I noticed I have squeaky brakes. Maybe a glaze or something?
Has anyone had this on their PJ and know how to get rid of it? It happens with normal brake pedal pressure.. Press hard and it goes away.
(kinda embarrassing )
Old 08-18-2012
08DANGURNEY 08DANGURNEY is offline
its not just the PJ Saleens its just about all of the saleens ive heard. It does it on mine also. I have a Dan Gurney Saleen.
Old 08-18-2012
emba129's Avatar
Maybe the pads need to be replaced with ceramic? Harder pads?
Old 08-19-2012
yeah its got to be the pads i get lots of brake dust
Old 08-19-2012
emba129's Avatar
me too.. after every drive.. gotta wipe the wheels
Old 08-21-2012
IGGY's Avatar
IGGY IGGY is offline
Smile Ceramics
I put ceramics on mine & it eliminated the noise plus the dust. very happy !
Old 08-21-2012
emba129's Avatar
Did you front and back? What brand did you use? We're they hard to change the fronts?
Chris
Old 08-21-2012
bandit67's Avatar
bandit67 bandit67 is offline
Fronts are a bit quicker to change than the rears in my opinion, though you'll need to spread the pistons when installing new, thicker pads, which can be difficult your first time without the right tools.
I've got one squealing brake with my street pads. Only time it squeaks is just as I'm coming to a stop. Not much dust compared to the stock Stoptech pads. I run Hawk HPS on the street. Stock Stoptech pads never squeaked. My experience is the harder the pads, the more they squeak, unless a stock pad gets a decent sized piece of grit stuck in it.
2007 SPJ #384, JLT Oil Separator, Bob's Auto Sports axle reservoir, AFCO radiator, FRPP coolant reservoir, StopTech 2-piece rotors, MGW shifter, DSS 3.5" alum driveshaft, JLT Series 3 CAI, custom VMP tune
330 rwhp, 334 ftlbs on Dynojet 224xLC on 8/20/12
2015 GT, Deep Impact Blue, PP, 6 sp manual
Previous Mustangs:
2015 EB Prem, Magnetic, PP, 6 sp auto
2007 Shelby GT, White/Silver, 5 sp manual
2007 GT500, Red w/white stripes, 6 sp manual
1981 Mustang GT 5.0, 4 sp manual
Old 08-22-2012
Aussie-Parnelli's Avatar
Hi Chris
Yes I changed all 4 sets of brakes,
Fronts are a bit easier to fit, you will have to push pistons back. Just do one pad at a time, then lever other pistons on other side back
Rears are trickier you need a special tool "available at any auto parts store" to wind the piston back in....to make life easier just loosen bleed valve as you do it.
Front are Ceramic Posi Quiet 105.06090
Rear Ceramic Powerstop Evolution 16 1082
Another distinct advantage is you don't get the brake dust problem any where near as bad as the other types
Hope this helps
Tony
1966 Shelby GT-350 LHD
Old 08-23-2012
emba129's Avatar
Super,
Thanks Tony
Old 11-28-2012
emba129's Avatar
Hi Tony, Im getting ready to pull the trigger on new brake pads.
Are the ceramic pads you put on your PJ's hard on the rotors?. Ive heard that ceramic pads are hard and the rotors get sacrificed first? Thoughts?
Also, Centric Posiquiet have rear pads.
Centric Parts 301.10820 Rear Premium Ceramic Disc Brake Pads
Any reason you chose the Powerstop Evolutions for the rear over the Posiquiets that you put on the front?
Chris
Old 12-03-2012
boston's Avatar
boston boston is offline
i put posi-quiets on the front, brake dust is virtually nil (less than stock rear) and no more squeal thank god. less grip and more fade than the big brake pads that come with the saleens, but we don't really drive on the track, we drive normally, right. that being said, i kept the pads in case i do take it to the track. i miss that grip sometimes ;) but the posi quiets are very nice.
06-1115 S281 SC Vista Blue Convertible
Old 12-03-2012
emba129's Avatar
I bought the Powerstop Evolutions for the rear
Old 08-13-2013
Stablemaster Stablemaster is offline
My PJ goes to the track regularly. I also show it regularly.
I use the StopTech pads on the front and EBC bluestuff pads on the rear.
I have tried everything mentioned here and found some issue with on track performance from everything else. I don't have squealing or squeaking issues with these at all.
Downside is that this pad combination make lots of dust.
I use this same combo on all my S197 Saleens.
Stablemaster
S281 SC 05-1285
S281 SC 06-1268 (Saleen Watts Link, Saleen Strut tower brace, Rear disc upgrade to slotted)
PJ-455 (Rear disc upgrade to slotted)
73 Mercury Cougar XR7
67 Mercury Marquis (Super Marauder)
67 Mercury Marquis (Marauder)
Other assorted Ford products
