Brake cooling ducts in the fascia
I finally put the useless stock brake cooling ducts to good use.
I used the 3" dia high temp 575 F silicone/wire duct hose, an adapter to convert the 4 1/4" duct opening in the fascia for the 3" dia hose and a hand-made bracket to attach/clamp the hose near the center of the brake rotor and disc vents. I checked the duct hose to tire clearance at both extreme tire positions (full left and full right) and no rubbing. Better fitment that other commercial brands I think.
jc
