Old 01-27-2014
2002-168's Avatar
2002-168 2002-168 is offline
Default Q: Aftermarket tubular K-member/stock a-arms? - 2002 S281
I need to replace my steering rack and I also have a set of long tube headers to install. Figured while I am down there I also want to install CC plates, Bump steer kit and a K-member for clearance issues. I want to keep my stock springs and struts. I am not against tubular a -arms but I also drive my car every day so I need to keep it reliable.
Anybody have a similar set up? any recommendations? Anything else I can improve while I have it apart?
This is a N/A car by the way.
2002-168 S281 1 of 10
BBK Fuel Pump
BBK Throttle Body
Aluminum Driveshaft
Cobra R Hood
Cobra Tail Lights
Long Tube headers
Quick ratio rack
MM solid steering shaft
CC Plates
1986-064 1 of 4
331
Edelbrock Aluminum heads
Holley Systemax Intake
Mac Long Tube headers
Resto-Mod completed 6/2014
Old 01-27-2014
jpstealth jpstealth is offline
I am doing something simliar except I'm doing the clutch and flywheel at the same time with my headers. I would suggest changing the oil pan gasket while the kmember is dropped though. I don't know how many miles you have on your car but I had that gasket go on two different engines in my 2000 GT; one at 80k the other at 44k and in order to change it you have the drop the kmember so might as well change it for $40 then have to drop it a second time if it ever starts leaking.
Black 04-0122 S/C
Series IV - Full Bolton - 2.8 pulley - Blower Cam
Only 9 PSI
403whp/406wtq
Old 01-27-2014
adam dawson adam dawson is offline
putting tubular a arms wont affect reliability at all. most k members use arms that are specific to the k members so most of the time stock a arms wont work.
just make sure you dont run a drag only setup. you want a sturdy k member and a arms, not something that skimps on strength for maximum weight reduction.
with the tubular a arms most require coil overs. you can use your struts with a coil over conversion. nice things are you can adjust ride height where ever you want, less weight and you will get improved ride quality from the reduced spring rate/wheel rate.
Old 01-28-2014
Consider swapping out the steering shaft for a maximum motorsports one to get a more direct feel. there's a lot of play in the stock steering wheel
Also consider:
  • Swapping out the stock rubber steering rack bushings and replacing them with urethane or aluminum bushings (I did the aluminum) Link to the ones I used with a stock K member
  • replacing the end links if they're worn
  • new thicker front swaybar
  • if you keep your old swaybar then you could at least change out the bushings
  • k member brace
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 01-28-2014
2002-168's Avatar
Looking at PA racing chromemoly K-Member & A arms with spring perches. MM Steering shaft,urethane rack bushings, steeda bump steer kit, maximum motorsports CC plates
Funny how simple switch to long tube headers and replacing a bad rack involves so much more ..... at least that's how I explained it to the wife
BBK Fuel Pump
BBK Throttle Body
Aluminum Driveshaft
Cobra R Hood
Cobra Tail Lights
Long Tube headers
Quick ratio rack
CC Plates
1986-064 1 of 4
331
Old 03-02-2014
I have a Granatelli tube '99-'04 K-member and stock A-arms in my fox body. They all bolted right up.
Old 01-08-2019
OxfordS281's Avatar
Admin delete please
2002 #48 Mineral Gray Extreme
Old 01-08-2019
OxfordS281's Avatar
Originally Posted by OxfordS281 View Post
Steeda is a good option
Old 01-09-2019
Default Steeda k member
Does the Steeda k member change any specs as you have with other k members. Never like the idea of my wheels scooting forward or backward in where they sit.
02-11E Saleen Convertible
Old 01-09-2019
OxfordS281's Avatar
Maximum motorsports has regular and forward offset control arms. The steeda will not push the wheels forward or backward.
