Aftermarket intercooler manufacturer?
I recently came across some information about a company called Griffin Thermal Products. They build custom radiators, heat exchangers and intercoolers. They have even made improved aftermarket intercoolers for 99-04 Saleen sc owners, with the same or similar results to the chicane unit, for several hundred dollars less.
Is anyone familiar w/ them or know someone who has done this? Here is there website:http://www.griffinrad.com/intercoolers.cfm Chicane makes a good product, but its very expensive and never in stock. Mine took several months to recieve....
03S281SC 03-269 Tunable induction CAI|2.8 pulley|39# Injectors|05 Mustang GT pump|90mm MAF|75MM BBK-TB|Mosaleen idler|MAC Long tube headers|Mac Off road X|LFP-H/E and tank|Chicane I/C|5gpm pump|373 FRPP gears|NT555R 305/35ZR1|MGW shifter|FRPP Alum driveshaft|N2MB two step 86-0087 03-269 S281SC 92 LX coupe 92 LX convertible |
Good find.....I was wondering how I'd get one to fit my front end. lol
That sucks. I recieved my intercooler in under a month and it had to be made as well. I believe you are talking about the heat exchanger Barrricade. I have thought about replacing that as well and I don't believe Chicane has one of those, but I haven't researched it much.
LFP Has a front Heat Exchanger made specifically for the 99-04 Saleens.
http://www.lightningforceperformance...leen_S281.html
I am really debating the HE given my other parts I have to install. Trying to get to where your at! LOL
(Remember...my gauge is measuring intercooler temperature on an '02....so that might not be as helpful for you). The chicane intercooler lowers your temps by about 30 degrees. LFP heat exchanger by about 10 degrees (so i've been told....i've never validated).
@ 130 it starts to pull small amounts of timing. @ 150+ it takes alot more and becomes noticeably slower. I'm making 10.5 psi w/ this pulley. That definately builds the heat quicker than a stock pulley. I agree w/ Evils numbers. He has an oversized tank, thats the one thing i didnt do. I just like the stock look under the hood. Straight water (no antifreeze) and water wetter got me another -5 deg. It all helps!!
