Q: Supershaker Hood cutout?
The Saleen Supershaker Kit has a "trim template" pattern for the Supershaker hood cutout and notes very, very slight cutout position difference between stock 2005-2009 GT Mustang hood and Saleen 2005-2009 S281SC vented hood.
1. Question does anyone have the Saleen "Trim Template" pattern, noted in Saleen install instructions, available from an older Supershaker installation? Available to sell, rent or whatever? 2. Perhaps a Saleen Supershaker owner with a Saleen SC vented hood could measure the distance from rear hood center to aft inside edge of plastic trim? Also measure distance from sides of hood to inside edge of plastic trim left side and right side? 3. If cutting a Saleen S181SC hood with vents....measure 3 times and cut only once? Any help to cut only once correctly, accurately would be very much appreciated! 4. CDC has a hood scoop cutout pattern but there is no guarantee that the CDC hood scoop pattern is in the "exact" same location as the Saleen Supershaker hood scoop cutout. As I noted, the location and pattern must be accurate/precisely located. Last edited by jrcalvin; 01-14-2021 at 12:25 AM. |
I would not cut an aluminum Saleen SC / vented hood at this point.
I remember when I cut mine I had the template. The template used the windshield washers as the reference point for the template. Prior to cutting I discovered my windshield washers weren’t where the template said they should be. Luckily I figured it out. Anyway, I took some measurements for you .
From the centre of the windshield side of the hood to the hole side of the trim ring is 11 1/2. From the side of the hood to the hole side of the trim ring is 22 1/8 from both sides. Hope this helps you. Let me know if you need any more. Last edited by tbar; 01-14-2021 at 05:35 PM. |
It only takes one person to answer a post accurately to appreciate this forum. And thank you "tbar" for once again taking the time to answer my question.
Yes, I do have the CDC hood template but the critical hood scoop cutout question was just like the Real Estate question.....location....location....location. Thank you again "tbar" for taking the time to provide the detailed information I needed for a Precise hood scoop cutout. And thanks for the pic too! Last edited by jrcalvin; 01-15-2021 at 12:38 PM. |
Jason | 281 Motorsports NO PM'S - PLEASE CALL | 714-575-1505 1996 Cobra Vortech SC / Track prepped 2015 Coyote Powered F-150 Check out our facility promo video here: http://bit.ly/1yHNfxM Email: 281motorsports@gmail.com Web: www.ProSpeedMustang.com Facebook: www.facebook.com/mustangperformance Youtube: http://bit.ly/1zOxanf "Doing the job right...is the ONLY option we offer!" |
Hey John
Just seen your post, I know I still have the Saleen template somewhere will search for it I made up this heavy cardboard template and taped it to the hood in correct position Used it several times and saved any damage to hood with the cutter After 3 months of trying to figure out problem with '06 it turned out to be the fuse box haven't pulled it to pieces as yet but there must be a bad connection somewhere inside, Had car dynoed yesterday 525RWHP feels really strong Tony
2008 Extreme S302E #02 RHD Saleen Demo/Press Parnelli Jones #45 Super Shaker RHD Parnelli Jones #46 Super Shaker RHD Parnelli Jones #407 Super Shaker RHD (SOLD) '06 GT Coupe "Saleen Racer" RHD 1970 GT-HO Falcon Phase 2 Owned since new 1966 Shelby GT-350 LHD 1965 TBird Conv. 429SCJ Drag Pak 4 speed |
Thanks for the info Tony: I thought you had changed the fuse box as one of your efforts to solve the non-start/running problem? Looking back I guess it is now easy to see that an "electrical short" problem is going to damage either a couple circuits and even the fuse box itself. Always easy to "look back".
I used multiple layers of tape to protect the hood and followed Jason's advice of "slow an careful with a new metal cutting blade". The cutout turned out very well and 'tbars" dimensional help confirmed the cutout location which I measured at least 3 or 4 times before starting. I not sure I believe that Saleen had a special front or rear "Shaker bracket" to account for the slightly higher Saleen hood. I think spacers were used to raise the front of the hood scoop intake level to the hood. No big deal. |
I used spacers as well to bring it up to the right height. There was no separate bracket in the kit for the Saleen hood.
I thought I would follow up on my questions about the location of the Supershaker Hood Cutout with pics of the final result.
Again, thank you "tbar" for your accurate inputs. |
Looks good! Good to see it worked out for you.
Wow! That looks great!
Question, is that the Saleen trim piece around the cutout? Is it held in place with tape only? Thanks, 'Coot
2008 302 Heritage 08-0029 |
Yes the hood cutout trim piece is fastened with only double-back tape. The tape is the MMM product but when used with the enclosed "adhesive promoter" it really sticks...as in one chance to get it right and it will not easily be removed.
Thank you!
