Old 08-11-2009
***Onetoughsoldier*** ***Onetoughsoldier*** is offline
Default Cold Air Intake Kit
I'm wanting to place a Cold Air Intake in my 07 Saleen S/C, There is a big difference between the Supercharged 4.6L Saleen engines and the regular GT 4.6L engines and I have yet to find one online. Does anyone have any ideas; or perhaps have already put a kit on their Saleen and can give me the website they bought it from?
Thanks,
Shawn
Old 08-11-2009
Stanghungry Stanghungry is offline
I bought a saleen extreme cold air from TPS.
Old 08-11-2009
redflagsc redflagsc is offline
get a supershaker...it's the coldest cai on the market
Old 08-13-2009
HotRodHarry's Avatar
HotRodHarry HotRodHarry is offline
I have the Saleen Ultimate Air Intake setup on my car....it does come with a new Mass Air unit also. And dont let the closed airfilter portion fuel you. Saleen spent alot of time on this design and it works pretty good on my 10 second 1/4 mile Saleen Supercharged stang. TeamJDM.com does the tuning for it spot on.
2006 Saleen 1534
11k miles ....5 speed..windveil blue.
My www.HotRodHarrys.com website
My Facebook Fan Page
Old 08-14-2009
diverdale diverdale is offline
I have the Steeda CAI with the carbon elbow. I like the way it looks
Old 08-14-2009
Thats real nice too ...some might have probs with that one clearing the alternator that is relocated when the Saleen Supercharger is on there. But that does looks like it has alot of clearance.
2006 Saleen 1534
Old 08-17-2009
JimIII@JDM's Avatar
JimIII@JDM JimIII@JDM is offline
Thanks,
Shawn
The best kits available for a Saleen car as tested by Team JDM....
$599-Saleen 08+ Extreme air kit (Ultimate air intake)
700+ RWHP Capable
$459-TechCo 100mm cold air kit
550+ RWHP Capable w/ stock maf sensor
$299-Saleen 98mm cold air kit
480 RWHP Capable
$299-C&L 95mm cold air kit (requires 1/2" lower than stock motor mounts)
480+ RWHP Capable w/ stock maf sensor
$450-JDM air kit w/ 90mm Lightning MAF & Saleen 98mm Rubber inlet
480+ RWHP Capable
I like the TechCo and the Saleen Ultimate air intakes the most. Both fit excellent and perform even better!
Team JDM, the Saleen Speedlab center!
www.TEAMJDM.com
732-780-0770
Old 08-18-2009
cdn_saleen05 cdn_saleen05 is offline
700+ RWHP Capable
480 RWHP Capable
480+ RWHP Capable
Have you ever worked with Steeda or JLT? What is the best one for a N/A Saleen out of all of these listed (in your opinion Jim) ?
Thx
Old 08-18-2009
JimIII@JDM's Avatar
Thx
JLT Wont fit with the Saleen blower because of the position of the altenator.
The Steeda carbon fiber tube will not work either because of the same issue. The air box will fit with the stock or Saleen 98mm rubber inlet boot.
The WMS air kit is another great option, retails under $400 and will handle up to 480 RWHP with the stock sensor
Also Supershaker FTW!!!!
www.TEAMJDM.com
732-780-0770
Old 08-18-2009
IWinULose IWinULose is offline
Jim, out of curiosity, do you sell the SuperShaker kit for the SC cars? Also, what modification was made to allow it to work on the SC hood? (I want the Supershaker, but refuse to rid my car of the SC hood.)
PS: Sorry for the hijack. =P
http://img28.imageshack.us/img28/3115/soecsig1.jpg
2007 Black SC Coupe
#07-0062
Old 08-18-2009
JimIII@JDM's Avatar
We sure do they are $1200 for the conversion kit and that includes everything you need to swap over. You send your PCM to Saleen or if you have or want an SCT xcal3 we can do the tune! The Supershaker is probably the highest flowing air kit for these cars, just be careful of heavy rain!
The power level capability on a Supershaker is around 550 RWHP on the stock MAF sensor. Check out this 08 Calif Special mustang we have running on the stock engine with one! http://teamjdmvideo.streetfire.net/r...e700970060.htm
www.TEAMJDM.com
732-780-0770
Old 08-18-2009
SC1039 SC1039 is offline
Just to add my .02 cent to this thread.
Be very careful with any CAI kit intended for a GT. I found out the hard (and expensive) way that the one I had gotten didn't fit properly under the Saleen SC aluminum hood. Bent it pretty badly where the filter cone and housing sit when I shut the hood. So my $300 CAI install turned into a $1600 hood replacement. If you have an SC hood you need to get a CAI kit designed for the Saleen SC car, like those sold by JDM.
[SIGPIC][/SIGPIC]
Old 08-19-2009
So I can run the stock Saleen SC hood with the $1200 kit? I just want to be certain that I can use the SC hood with the SuperShaker, otherwise, I am going to go with the TechCo hood.
My car has been caught in light rain 3 times. Other than that, I avoid rain at all costs. So that shouldn't be an issue.
2007 Black SC Coupe
#07-0062
Old 08-19-2009
Any idea if the WMS needs to be re tuned? hp gains?
Any members here have this on there vehicle?
Old 08-19-2009
You'll have to cut a hole in the hood for the intake. Doing so on an aluminum hood could be tricky. Also, as I understand it, the Techco hood is not designed for the Supershaker (although it should be). Its airflow routing is designed for a "normal" intake position.
[SIGPIC][/SIGPIC]
Old 08-19-2009
I like the TechCo hood as is. I would skip the supershaker mod if it won't work with the SC hood. The SC hood has a little more rise to it than the regular GT hood. That's what I am worried about.
2007 Black SC Coupe
#07-0062
Old 08-19-2009
Yea good point, I haven't seen any pictures of a Supershaker install with an SC hood. The intake slots could be partially covered by the hood. That TechCo hood looks so good I'd be easily persuaded to go that route anyway.
Edit:
Actually, from another forum....
But I have no idea if that was with some modifications or not.
http://i295.photobucket.com/albums/m...z/DSC05744.jpg
[SIGPIC][/SIGPIC]
Old 08-19-2009
david01130 david01130 is offline
The supershaker fits the darkhorse with the SC hood and it looks like it does it with no problems. $1700 for the techco hood is a little pricey. Its a clean hood but if I saw someone with a supershaker and a nasty SC whine Id wet my panties
Old 08-19-2009
Do any of the Dark Horse engine compartment photos reveal if a spacer was employed to lift the assembly? It was talked about, but I never heard or saw much on the matter in detail.
With the reorganization of Techco, I might not delay the idea of attaining a SMS 25 Concept hood. One never knows.
Old 08-20-2009
That is exactly what I am talking about. I saw those pictures before the SuperShaker was ever released, and the rumor was there was a spacer being developed to allow the Shaker to sit above the SC hood's extra rise. I never heard anymore about it. Please let it be so that it will work with the SC hood.
2007 Black SC Coupe
#07-0062
