Wheel offset
In looking to possibly get a second set of wheels for my 07, I've run into a question of wheel offset differences.
What, if anything, would be the effect of a set of new rear wheels having 5mm greater offset than the current set? Would this create any issues, problems, etc? Thanks for your help! |
The lower the offset #, the further the wheel will stick out. I run 26mm offset wheels on my GT and they stick out just a lil bit past the fender, i have 275-40-18's. If you are planning to run the rear wheels with a lower numerical offset and a tall tire, you may run into rubbing issues with the fender.
you might be able to use this site to get an idea of just how both tires and wheels will fit. hope it helps you
http://bigcustomwheels.com/ QWKENUF Craig |
