Old 10-11-2010
02S/Csaleen 02S/Csaleen is offline
Default Stock intercooler gap seal question?
I'm attaching pictures to give you idea. Chicane sells their intercooler that makes all air go through it and not around. I don't want to spend 799.00 simple as that. I've seen some threads pop up and die about designing a custom plate to seal off the gaps.
Is their any cheap way to seal off the intercooler. I don't ever care to remove the intercooler from the intake manifold. Looks like I could use some kind of liquid that gets really hard and is resistant to high temps, maybe to stuff the gaps.
Old 10-11-2010
SonicBlue's Avatar
SonicBlue SonicBlue is offline
Your just asking for trouble trying to do it that way!
Do yourself a favor adn leave teh car as is or do what most of us have done adn shell out teh money on teh Chicane piece! It's worth it to do it teh right way 1 time!
'03 SC Coupe (1 of 2) 380hp / 400tq @ 12lbs boost 18x10" rear wheel option
13" Saleen Brakes ◄ Chicane Intercooler ◄ 2.875" VI Xtreme Pulley ◄ 4" polished CAI
75mm TB ◄ Bassani Exhaust (Mid Length Headers, X-Pipe, Mufflers) ◄ FRPP 3.73 gears
90mm MAF/42lb Inj ◄ Ford GT Fuel Pump ◄ Rear LCA's ◄ Subframe Connectors + more!
Old 10-12-2010
disco's Avatar
disco disco is offline
griffen makes the intercooler too a little cheaper although i have no idea what it looks like but they say it takes care of the gap
00gt 10k on the clock saleen s4 blower and full saleen body kit. 2.76 upper, 42's , 90mm maf, 75mm tb, focus pump. high flow cats, stock gt exhaust, 31splines and 373's. best et without body kit was 11.9 at 116mph on et streets. 1.60 sixty foot. way more to come out of this combo sct tuned by me.
Old 10-12-2010
SonicBlue's Avatar
From what I understand (could be wrong) but Chicane takes the Griffen IC and improves on it, then sells it for their cost.
Old 10-12-2010
disco's Avatar
yea not sure i talked to griffen yesturday and they say it takes care of the gaps
Old 10-12-2010
Price?
Sent off the M90 supercharger today for porting, looking to possibly get the manifold ported. So adding a intercooler would just be awesome.
Old 10-12-2010
disco's Avatar
550 i can prob get them to do better
Old 10-13-2010
2FNFAST 2FNFAST is offline
High temp silicone works just fine.... Use a load and make sure its all connected so it drys in one piece... did it for 6k miles with a 2.2 kenne on top of it pushing 18 psi and it didnt move a bit... I actually have the manifold sitting in my garage with the blower off, ill post a pic tomorrow...
Old 10-13-2010
Exactly the response I was looking for. No need to spend 800 dollars when you can fill the gaps with high temp silicone. I would love to see a picture :D
Old 10-13-2010
disco's Avatar
filling the gaps along with a bigger intercooler res should really lower the temps.
Old 10-13-2010
I have a much larger reservoir and dual bypass heat exchanger. My last step was to seal off the intercooler by any means necessary.
Old 10-13-2010
disco's Avatar
you got it luckily in the ne we get a nice cool fall and of course winter and let me tell you my car the other day even when it was in 40's out the air charge was in the upper 80's and 90's rolling into 2nd boils the tires and third spins good too. night and day difference
Old 10-14-2010
apicia apicia is offline
I would also clean that intercooler. Can't be too efficient covered in oil. After a new intercooler or a cleaning, eliminate all sources of oil from entering the intake.
Old 10-15-2010
:D Did that last night. The intercooler is actually silver haha. I also have eliminated that hose that runs from the valve cover to the intake, so no way is oil getting into the system now.
Old 10-19-2010
Werecow Werecow is offline
Lets not forget the Chican IC, regardless of who makes the core, is a superior bar design which in turn cools better as well, not to mention it is a hell of a lot bigger. Simply closing the gaps won't make up all the cooling gains that you will experience with the Chicane piece.
Old 10-19-2010
Well i'm just not allowed to spend $800. **** wife
So I have a place up the road called SS Customs making me a plate then welding it onto the intercooler very carefully. Only $300
I know I won't see the gains like I would from chicane, but it will help regardless. Along with my larger reservoir tank and lfp heat exchanger the temps should be great for 11-12psi
Old 11-01-2010
So I caved and bought the Chicane. Anyone know what I can get for my stock intercooler?
Old 11-05-2010
Take anything anyone will give you???
Old 11-05-2010
Will do. Got it on ebay for starting bid of 75 bucks and got 15 watchers already.
Old 11-08-2010
Why the caving? What happened to the plate that the shop was going to make for you?
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 11-08-2010
The guy was taking his time. Then he ran into the problem of bending the metal. Then he took 2 weeks off work. Seems like he didn't want to do it.
So I'm happy with the Chicane purchase.
So evil I seemed to have cracked the ****ty plastic intake. Looks like I might also have to purchase the tork teck piece. Since I have mine EGR deleted will it make the install easier?
