Old 08-13-2006
mcollins mcollins is offline
Default Q: S281 SC upgrades?
hi i have a s281 sc with 8 k miles, i have heard it has 365 hp and runs low 13's. i have cool air intake and a shortshifter, and im wondering whats a good exhaust to get cause i want it to be louder so im deciding on a steeda cat-back. has any1 heard that or what else have you heard that will give it a loud muscley roar. also it im a little disappointed in the performance so i also open to other suggestions on what to get, i kind of want to get up to a little over 400 bhp but i have no clue wat to get to get me to my goal. i live in nj and have heard jdm in freehold is a good place to go and thats not far from me. please reply on any suggestions
Old 11-06-2006
Saleen01-583 Saleen01-583 is offline
I was told to add 30lb injectors and also change the superchager pulley and then have it re-calibrated, it would then give it 500 HP. I have yet to locate and shop in my area.
Old 08-06-2007
Dave281SC Dave281SC is offline
01 on up SC models (except the Exbreme) should already have the 30lb injectors. I know my 01 does. 99-00 have 24lbs. As for taking it over 400hp I would go to far beyond that because the internals are not forged internals. I would say 9psi of boost would be tops and not go over 425hp. I know that chicane autosports has a pulley upgrade to incease hp by 30. I have already upgraded my TB to a 75mm and plan on LT headers with hi-flow cats x-pipe/or h-pipe, Chicane RIPP kit , 3:73 gears and a good tune. I don't plan on going over 415 until I beef up the bottom end and do some head work, 42lb injectors, upgraded fuel pump and stage 2 clutch.
Old 08-06-2007
03SaleenStang 03SaleenStang is offline
i have the chicane pulley upgrade, BBK long tube headers,magnaflow cat back exhuast and got it tuned good hp upgrades... the magnaflow mufflers i told were one of the best to get because there chamberless which also makes a nice sound...my next project is to switch from the h-pipe to the Bassani x-pipe and go back to being cat-less
"Power in the Hands of A Few"
Old 08-31-2007
01SCVert#265 01SCVert#265 is offline
How do you go cat-less and still pass the NYS emissions/safety inspection?
Old 03-26-2008
03-246 03-246 is offline
Default Suspension is where it's at!
All of the power/performance enhancements that you are talking about are great...I've done most of them (MAF, Steeda dual fuel pumps, 42# injectors, hotter plugs, chicane pully, BBK high flow cats, 75mm throttle body, etc.) and had the care tuned by JDM in Freehold NJ....they are the best! The power is a much more respectible 375 rwhp. But with all of that said, the car still handled like junk during open track days. Anywhere in the 300 - 400 hp range is great, but where you should be investing your money is in suspension and brakes. Even on the Extreme cars, Saleen still uses the puny 10.5" solid GT rotors from Ford. In some cases they upgrade the fronts to 13" Brembo's, which definitely helps. I installed Cobra rear capliers and 11.65" Brembo slotted/vented rear rotors. This combinationn brought down brake temps (and stopping distances) by several hundred degrees. Regarding suspension, with the exception of springs, struts and bushings, most everything else is junk stock GT stuff...which simply isn't worthy of track duty. I would STRONGLY suggest that you check out www.griggsracing.com if you want you car to handle like it should. They originated late model Mustang suspension systems and when installed, your car will run circles around more extotic iron costing 3x - 4x as much.
[I][B]2014 Shelby GT500, SVTPP, Track Pack, Recaros, Nav, Deep Impact Blue w/ White Stripe
2012 Shelby GT500, SVTPP, Recaros, Nav, Black w/ Stripe Delete (sold 1/27/14)
2003 Saleen SC Speedster 03-246 (sold 4/25/11)
2002 Roush Stage 3 World Challenge GR40 - Race Car (sold 5/29/12)[/B][/I]
Old 03-30-2008
mills281e mills281e is offline
I think different year Extremes had different brake set-ups (Alcon vs. Brembo). Mine came with 13 inch slotted Alcons up front. As you mentioned, the rears are still factory GT rears. But, how much braking do the rears actually do? The 2003 and 2004 Extremes came with 14 inch front rotors.
Larger injectors with a pulley swap and tune will not get you to 500 hp irrespective of SC or Extreme. I did MAF, TB, switch from a 4 inch to a 3.5 pulley, SCT chip and tune and got to 400 rwhp/400 rwtq (approx. 470 hp and tq at the crank). It wasn't until I went down to a 2.6 inch pulley, installed the CHicane intercooler and upgraded my fuel delivery that got me to 440 rwhp/ 484 rwtq (approx. 520 crank hp/570 crank tq).
Keeping in mind, this was all with the Extreme's 2.3L Series V supercharger and forged internals. Therefore, your numbers will be somewhat less (as well as less safe, as Dave mentioned) with the Series I, II and IV superchargers and stock internals. Not trying to come across as a bastard or anything....I just hate to see people get very disappointed when they do mods. and come up really short based on their expectations.
Old 03-30-2008
mosaleen's Avatar
mosaleen mosaleen is offline
Mills is right. Most series I or II blowers with standard mods (no LFP heat exchanger or Chicanes intercooler) will be lucky to make 300 to 340 rwhp thats 360 to 400 bhp (flywheel). MY 2000 Series I made 334 rwhp 375 rwtq (2.60 pulley ported series I, x pipe with high flow cats, shorty headers, X cal. II tuner, CAI , ford 65 mm T/B ,39lb inj. SVT Focus fuel pump. I didnt want to replace the blower (its a Saleen) so I added 100 shot of NOS , withall the goodies, MSN window switch,heater, etc.
For all Supercharged Saleens I make a S/C idler pulley system that really works it fits between the S/c pulley and the power steering pulley stopping belt slipping and deflection. I gained 1 lb of boost 34 rwhp and 42 rwtq on my 2000 Saleen. JDM Engineering has tested these and Im almost done with the 2005 - 2009 , which im sending to JDM to test on there race Saleen.... I have a brocher if anyone is interested.
email: svanhoose57@hotmail.com
3:73 gears, Watts link Gen II
Old 05-02-2008
fud fud is offline
I just got a '99 281 (SC) from a friend. I love the exhaust note, but let's face it, it should wake the dead.
So, what recommendations do you folks have for exhaust?
Being that I live in Indiana, there's no worries about emissions, but we do pay out the *** for license plates...
Old 05-02-2008
Off-Road (no converters) H and X-pipes will give you the increase in sound you want.
You can also do headers with a catless H or X-pipe. Depends on how much you want to spend and how quickly you want the job done.
Old 05-03-2008
fud fud is offline
I've got a friend that's a mechanic, how quickly it gets done is proportional to the amount of beer I pay him with and how much is consumed...:)
Old 01-21-2019
jklein jklein is offline
Does anyone have a list of the upgrades that could be chosen for the 2004 SC281
Old 01-23-2019
saleen556 saleen556 is offline
What kind of power are you looking to get? I had an 02 that put down over 600 at the wheels. It was quite a process. I could probably lead you in the right direction.
2017 Z06 stock for now.
Old 02-07-2019
Check my signature. All but the Tork Tech intake would work on your car.
I strongly recommend the suspension updates like the subframe connectors because the chassis has a lot of flex.
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 02-07-2019
I couldnt agree more! The Maximum Motorsports suspension/chassis packages should be on the top of anyones list that wants the car to plant its horsepower. Its always shocking people always call for horsepower but rarely ever call for traction.
