4.56 gears and brakes
Hi guys will be looking at 4.56 gear upgrade what size will i need is it 9.75"? and what brands are reccomended and where from?
also anyone whos fitted the 4.56 gears what does it do to top speed? also in need of two of the 15" brake discs, again anyone know where from and how much i should expect to pay? thanks guys Last edited by SaleenDriver; 01-16-2012 at 03:23 PM. |
also does anyone know where i may find the original Rockford Fosgate sub to fit under the rear seat, or is there a company who makes a sub/box to fit?
Yukon gear sets are, in my opinion, the best gearset and the easiest to setup. I work at a tranny rebuild center and our other shop does a lot of gear work.
Yes there a 9.75 gear. I've used pro5.0 and ford racing gears. Both were really easy to install. Alot of people prefer ford racing because there cut on the same machine as the factory ford gears so they seem to install better. As for the rockford box i looked everywhere for one. F150online and f150forum usually has one for sale if you can get tk it before someone else. Are you needing The pads or rotors? Stoptech sells the rotors. Saleen sells the pads for $200. But you can just buy late model excursion,f250-350 pads there the same thing for around 45 for a set of ceramic pads.
I dident have gears in my truck but other ppl with 331 are running approximately 2500rpm at 70, that's not bad at all my awd tbss runs 2000-2000 at 70 with 4.10's.
