Any S331 SC Dyno Numbers?
Has anyone dynoed there truck for a stock HP base number? Am preparing to purchase the JDM kit and wanted to compare original HP #'s before installing. If you can tell, I'm disapointed in the trucks power. My old 02 Harley f150 would run circles around this truck. Ford is putting a new fuel pump in my truck because pressure was low, and accidently erased all Sallen mods out of PCM. Had to be sent back to Saleen for reprograming.
Thanks for your responses, Rick |
Stock numbers on a dyno are around 360-370 to the wheels. The JDM kit will more than wake up your truck, it will feel like a totally different vehicle. It will make you wonder why Saleen didn't do it this way from the get go.
My numbers were slightly less (10-15), but it is hot as hell down here. My shop recommended upgrading the heat exchanger, so that's probably what I'll end up doing...
Call JDM, they have an upgraded heat exchanger for your truck. In stock config., it will definately run hot and produce low numbers.
Yeah I have seen it on their website. They are supposed to be opening a shop down here next to HRP, but it keeps getting delayed for various reasons from what I am told. I would really like to have them start working on my truck, seeing as how they are pretty much the authority on these things. So hopefully it will still end up happening cause I still have some plans for this thing!
It's definately happening, all in good time my friend.
