Old 06-14-2022
Hawaiian Saleen Hawaiian Saleen is offline
Default Cylinder head torque for a Series 2
Aloha, I am the second owner of a 2001 GT that was converted when new by the original owner to a Series 2 with all the proper Saleen equipment. He sold it to me because he couldn't drive anymore and the car had blown a head gasket. I had the heads machined and put the engine back together and torqued the heads to the factory specs. All was well until I opened it up a few times with some good boost and both gaskets blew again. I'm doing something wrong...
So, my question is, are the torque specs different (higher) for the heads when running the supercharger? It would make sense if it was. Any help would be greatly appreciated, thanks!
** the heads are orig. equipment 2001 GT
Old 06-18-2022
Default head gasket
Hello if I am not mistaken you should be fine with the oem torque spec even if you are supercharged as Saleen did not modify the engines on their regular 2v SC cars. And non SC cars just got pulleys. The only engine that got the forged / build treatment would be the Extreme. I would look into your gasket that you used. I'd use OEM Ford. Also some folks use a combination of gasket and gasket maker. Make sure you have a smooth clean surface as well. Make sure gasket is in place when adding the heads as the slightest movement can ruin your seal. Also, the torque tool you are using make sure it is to spec as over-torque can be just as bad. Oh yes try youtube as well. Let us know what you find.
02-11E Saleen Convertible
Old 06-26-2022
Thanks for the great advice. I used Felpro gaskets but I'll use OEM Ford gaskets this time, it makes sense. I'll post again after I put it back together.
Tags
head gasket, series 2, torque specs
