Old 02-04-2012
jasher0007 jasher0007 is offline
Default Q: Upgrade water pump with new heat exchanger?
I need help deciding what’s best for my car. I have a 2005 saleen S281 SC. I purchased a steeda heat exchanger in place of the stock exchanger. The size is of the steeda is huge when compared to stock. The question I have is about the stock water pump. Should I use the stock water pump, or should I go with a larger one? Any help would be appreciated. If I need to go with a bigger water pump, then could you guys follow up with why? Thanks
Old 02-04-2012
I have the Afco heat exchanger.The stock pump works fine for me.
Old 02-05-2012
OneQwkStang's Avatar
Gords Heat Exchanger http://www.gordsfordperformance.com/ with a Meziere pump http://www.meziere.com/
Old 02-05-2012
RedFire281 RedFire281 is offline
The Steeda H/E is a single pass and not as restrictive as a dual pass like the AFCO. As such, if you're using the stock reservoir, then IMO, the stock water pump is good for street applications (Unless you're short tracking the car). With the small shampoo bottle reservoir, a higher flowing water pump might pass the coolant too quickly through the H/E before it can efficiently cool the fluid. I'd say stay with the stock water pump.
Old 02-05-2012
FR500GT's Avatar
FR500GT FR500GT is offline
Running the AFCO unit here as well
Old 02-05-2012
Default heat exchanger
I am not racing or short tracking the car. Is anyone running the steeda unit on their car?
Old 02-05-2012
tbrock's Avatar
tbrock tbrock is offline
Running an afco unit with a larger intercooler tank which does a great job when I track my car. I know the saleen upgraded heat exchanger uses a higher flow pump. There is a great thread on the s197 forum about the idea of a larger heat exchanger and a higher flowing intercooler pump. I also upgraded to the new 6.5 lid which relocates the IAT sending unit which gives a more consistent reading keeping the ecu from pulling timing.
2007 Shelby GT, Saleen SC Stage 3 with 3.0 pulley,mosaleen tensioner sys. UCA,LCA,BMR A arm Brace, SVE Dark Stainless 18x10's, Nitto NT05's, MGW Shifter, Pypes LT's with off-road X pipe, Bassani Axle backs, FRP 3.73's,BMR Watts Link, Steeda shaft loop, JLT 110mm CAI, FRP valve Covers, Brenspeed tuned. 12.425@114.63 4800 feet on Nitto 555's. Latest dyno is 492hp/463tq.
Old 02-05-2012
T Brock, do you have the link. What tank did you go with, and are running a larger pump? I have the saleen supershaker kit on the car. Have the entire space where the air lid was located.
Old 02-05-2012
tbrock's Avatar
Here is the link to the thread http://www.s197forum.com/forum/showthread.php?t=52701
Currently I'm running a modified Canton GT500 IC tank where my power steering tank used to be and I relocated the PS tank to the drivers side strut tower on a bracket. I attached my stock intercooler pump to the bracket on the AFCO heat exchanger. After driving the car hard at track events and not seeing a huge increase in IA Temps I decided against the Meizer pump which you can get from Steeda for $200. Later this spring I am going to switch to this tank by Lethal http://www.lethalperformance.com/05-...ervoir-p-33763
as I am running the JLT 110mm MAF/CAI and I have sufficient room for it. I'll try to grab a picture here in a few to post.
Old 02-06-2012
tbrock, what kinda IAT's are you getting, say normal driving on a hot summer day and track days?
I am running a 3.2 pulley too, kinda interested.
Old 02-06-2012
tbrock's Avatar
When I had the old lid on around town it would stay around 110 degrees (summer time 90+ weather) and then go up from that point when getting into the boost. After a few WOT runs it would stay at 125 or higher until I drove around to cool it off. Now around town it barely registers and even in the boost it stays around 100-110 and drops very quickly. The new lid and subsequent relocation of the IA sensor really changes what I see on my gauge. The old system seemed to read the temp all the time and now it seems the sensor only really reads the temp when you are in boost. Certainly keeps the ECU from pulling the timing due to heat soak. I think the oversize IC tank and AFCO's extra capacity really aid in keeping the temps down.
Old 02-06-2012
Ok so here's some basic suggestions on HE and Pumps.
If your running a non-fanned AFCO (smaller core - about twice the size of a standard Saleen HE) you really dont need a better pump.
If your running a fanned AFCO unit (larger core - about 3 times the size of a standard Saleen HE) then you really should run a Meziere inline pump.
The 6gpm flow rate of the Bosch pump used on the Saleen's, Ford lighnting and I believe the Terminator Cobra, works fine on a smaller core. But once you drastically increase the fluid capacity of the cooling system, you will see the flow rate drop even more. This is especially true in AFCO's dual pass systems. Other brands dont use the better dual pass systems and are not as effecient in cooling the tempuratures.
To answer the original question, the Steeda unit is not a dual pass unit and as long as your pump is in good condition flowing the proper rate, you should be fine. I strongly recommend that anyone going to purchase a HE, to get an AFCO, or atleast a dual pass.
Old 02-06-2012
GORDS HE Specs.
Quality, Fit and Function.
When looking to purchase a replacement heat exchanger, quality and fit is extremely important. Having to modify your vehicles' front-end structure can reduce structural integrity and lower the value of your car.
The GordsFord Heat Exchanger was designed to fit in the stock location without modification of the factory bumper and retains the angle "L" brace- which is designed to protect the under-carriage and cooling assemblies.
The GordsFord Heat Exchanger utilizes the most open space of any aftermarket heat exchanger. Combine the largest frontal area with an optimal core depth of 2.375", the GordsFord unit attains the largest cooling volume and effectiveness.
Stock HE
Fluidyne
Xtreme
AFCO
GordsFord
OverAll Dimensions
Horizontal Length (in.)
26
21.5
29
26.5
31
Vertical Depth (in.)
6
6.5
6
6
6.5
Thickness (in.)
1.2
3.25
2.5
2.5
2.45
Core Dimensions
22.5
18
25.5
24
27.5
6
6.5
6
5.125
6.5
Thickness (in.)
1.2
3.25
2.375
2.375
2.375
Area (sq. in.)
135
117
153
144
184.25
Effective open area
22.5
18
25.5
24
27.5
5.5
5.625
5.375
5.125
6
Area (sq. in.)
123.75
101.25
137.10
123
135
Volume (cu. in.)
143.6
255.7
277.6
249
331.7
Effective Capacity
Cooling Ratio
1.0
1.78
1.93
1.73
2.31
Fit and Finish
Hidden End Tanks
No
No
No
No
Yes
Stock Mountings
Yes
Yes
No
Yes
Yes
Fan Kit/Wiring Kit
No
No
Optional
No
Optional
Colors
Black
Alum w/Logo
Alum/Blk
Alum
Alu/Blk/Logo
Retain Protective "L" Brace
Yes
Yes
No
Yes
Yes
Protective Screen
No
No
No
No
Optional
All Fittings/Connections
N/A
No
No
No
Yes
Note: All measurments were taken from actual production units using the same standard of measurment between units.
Track results will be made available soon once the heat of summer allows proper heatsoak conditions to validate any tests.
Old 02-06-2012
I noticed they left out the AFCO twin fanned unit, which is a staggering 26.5 x 12 x 2.5 for a total of 318sq inches of cooling. Then equip it with twin 10" SPAL fans and the cooling efforts "blow" the compitition away!
Originally Posted by OneQwkStang View Post
GORDS HE Specs.
Stock HE
Fluidyne
Xtreme
AFCO
GordsFord
OverAll Dimensions
26
21.5
29
26.5
31
6
6.5
6
6
6.5
Thickness (in.)
1.2
3.25
2.5
2.5
2.45
Core Dimensions
22.5
18
25.5
24
27.5
6
6.5
6
5.125
6.5
Thickness (in.)
1.2
3.25
2.375
2.375
2.375
Area (sq. in.)
135
117
153
144
184.25
Effective open area
22.5
18
25.5
24
27.5
5.5
5.625
5.375
5.125
6
Area (sq. in.)
123.75
101.25
137.10
123
135
Volume (cu. in.)
143.6
255.7
277.6
249
331.7
Effective Capacity
Cooling Ratio
1.0
1.78
1.93
1.73
2.31
Fit and Finish
Hidden End Tanks
No
No
No
No
Yes
Stock Mountings
Yes
Yes
No
Yes
Yes
Fan Kit/Wiring Kit
No
No
Optional
No
Optional
Colors
Black
Alum w/Logo
Alum/Blk
Alum
Alu/Blk/Logo
Yes
Yes
No
Yes
Yes
Protective Screen
No
No
No
No
Optional
N/A
No
No
No
Yes
Old 02-06-2012
jasaleen0718 jasaleen0718 is offline
Well, I found all this info to late. Trying to make desision, I ended up getting the Saleen Mod upgrade with pump. I dont beleive they offer a larger tank. Does anyone know where I can find one that will mount where the stock Saleen tank is. Cant put the tank Afco offers as I think power stearing tank is mounted where they show it on the GT500 vid they made. Any help appreciated..
Old 02-06-2012
We have located them in lots of different locations. Where did you want your tank to be?
Old 02-06-2012
I would like to put it where the stock one is if possible. Where else have you put them and how much bigger are they than stock. It seems I have no place to put it up front.
Old 02-07-2012
tbrock's Avatar
JPC has a nice tank that replace the stock tank.
Old 02-07-2012
JPC Racing has a large tank that goes in the stock location.
Old 02-07-2012
You mean something like this?
http://store.jpcracing.com/JPC-Racin...ck_p_1708.html
Old 02-07-2012
I don't recommend putting an aluminum tank where you phyisically trap heat from the headers between the inner fender and the valve cover. You might as well sit it on a burner. The fittment between the valve cover and the fender is so tight it rubs on both sides. Ask barricade, we encountered this issue when we installed his. Your better off with the stock tank.
If you want a better solution, Moroso makes one that sits in the battery tray. http://www.281motorsports.com/produc...roducts_id=902 and you get the benefit of putting the battery in the trunk giving you better weight distribution.
You could always relocate the PCM and fuse box and we custom build them for that spot! Lol
Old 02-07-2012
Jason, I am running a supershaker--so I have the room where the stock air box would set.
Old 02-07-2012
Gray is Grey's Avatar
Gray is Grey Gray is Grey is offline
Does your momma still tuck you in at night?
http://www.281motorsports.com/produc...oducts_id=2230
Search engines are amazing!
05-653 Mineral Grey
Brenspeed Stage 3 / Aluminum hood / Shaved antenna / This,that and the other.
Old 02-07-2012
Originally Posted by gray is grey View Post
does your momma still tuck you in at night?
lol.........
Old 02-07-2012
I like that setup. Thanks Grey _Grey.
Jason What comes with this kit?
Old 02-07-2012
lol!
Old 02-07-2012
The tank and the kit comes complete with hoses and fittings.
Old 02-07-2012
Sounds good Jason. I will call you at your shop tomorrow.
Old 02-08-2012
Jon Jon is offline
Accidentally posted twice, see next post
Old 02-08-2012
Jon Jon is offline
I'm running the Steeda H/E and have been for 3 1/2 yrs and 40k + miles, I live in Orlando where the summers are brutal and average temps on a 90+ degree day with the a/c on is usually between 115-130 and I have NEVER seen it above 140.... Also I sent you a PM regarding the 4.10 gears I'm selling... Hope this helps
Old 02-08-2012
Are you using the stock water pump?
Old 02-08-2012
Meikol02's Avatar
Meikol02 Meikol02 is offline
Hey Barricade got his picture on the JPC website! (the black tank picture)
Michael
'07-0449
Old 02-09-2012
Barricade's Avatar
Huh? I did??
-ǝsınƃsıp uı ʇoqoɹ-
BARRICADE 643
06-108E
Old 02-09-2012
Jeepngli Jeepngli is offline
For anyone with the AFCO heat exchanger, is it directly bolt in for our saleens? I mean no modifications? I'm looking at the non-fan AFCO exchanger. Thanks!
Old 02-09-2012
direct bolt in , simple install
Old 02-09-2012
It will take you more time to drain the coolant I think!
Remove hoses / drain
Un-bolt
bolt
attach hoses
prime, refill and clear out air pockets.
Id say about 45-60 mins if you take your time.
Old 02-10-2012
FR500GT's Avatar
Is it easy to do? YES
Is it a "direct" bolt on? No
(You will have to re-route the 2 attaching hoses and they dont come with the heat exchanger. Its easy though; you just need two 3/4" 90 degree hoses for the pump side and one 3/4"straight hose for the other side)
All in all, the install is very easy to do. Everything is very straight forward and once you pull the front bumper off the install takes less than an hour! The best part is that your SC will run much cooler now...oh and your Saleen will look a lot more aggressive coming up behind someone
Old 02-10-2012
Sweet. i plan to do the exchange in the summer. right now im just going to do the jpc tank. silly question, but whats the best way to drain the coolant our of the intercooler system? is there a drain plug on it?
thanks guys. i made 411hp on 5lbs so id like to keep what little power i have in the summer when my temps are rising.
Old 02-10-2012
You need to work for us!
I would consider "not" doing this.
Old 02-10-2012
Why do you say that? i am slowly building the car up and plan to keep the blower. id like to have the supporting mods there for when i up the boost. what is your reasoning?
Old 02-10-2012
Please see post 21 on this thread.
Old 02-10-2012
But realistically, whether its near the valve cover or where the battery is, any engine compartment with headers is going to be pretty hot. It may take longer to heat up, but I'm sure an aluminum tank even where the battery is will get cooked pretty good. Do you disagree? The only real safe solution is to put the tank itself in the trunk.
I'm just saying the stock beer can is pretty small and while it may not conduct as fast as the aluminum, once it does get up to temp its going to act like an insulator and try to keep heat in. On the other hand, the aluminum will heat up, yes. But aluminum will also dissipate the heat faster, like a heat sink. I dunno.
Old 02-10-2012
It literally traps the heat. You will see what I'm saying when you install it. The battery tank gets cover by the poly plastic battery tray.
Old 02-11-2012
So would you recommend just doing the AFCO exchanger and keep my beer can? I don't want to relocate the battery, thats why thats out for now.
  #45
Old 02-13-2012
FR500GT's Avatar
haha let me know if you're serious. Im currently the Ast. Manager at the shop but I'm ready for a change!
  #46
Old 02-13-2012
Send me a resume ASAP!
  #47
Old 02-14-2012
redruder's Avatar
redruder redruder is offline
How about relocating the windshield fluid reservoir and putting a larger tank there. It would have incoming air passing over it to help cool things off and keep it out of the hot engine bay. It would just be a matter of having a fill tube welded on that runs up to a workable location.
http://i1278.photobucket.com/albums/...der/4-Copy.jpgS281-E #06-0036
Best daily driver ever.
  #48
Old 02-22-2012
ERdoc ERdoc is offline
Can somebody tell me the part number of the Afco heat exchanger non-fanned?
Is it 80275NDP ??
I want to order that unit!
  #49
Old 02-23-2012
Is it 80275NDP ??
The part number is an 80280. You can find it here: http://www.281motorsports.com/produc...oducts_id=2228
  #50
Old 02-23-2012
Meikol02's Avatar
Originally Posted by Barricade View Post
Huh? I did??
Yes, look at the pic of the black Tank... you should recognize Matt's handy work on the lid!
Michael
'07-0449
