Help: Series VI supercharger squeak
Hello all I have a 2005 with the series vi blower I've already replaced the lower plastic pulley from saleen. There is a sqeauking noise that has now developed into a sqeaul upon startup and gets louder and faster the higher the car revs, noise seems to be coming from belt tensioner. I've replaced the tensioner the tensioner pulley the belt idler pulley and water pump pulley and the sound persists not even soaping the belt will quiet it down anymore! Any suggestions as to what it might be?
Have you changed your belt? Is there any belt residue on the pulleys/motor?
2005 Dodge Ram SRT-10 QC 2006 Dodge Ram SRT-10 RC 2006-1296 Ford Mustang Saleen SC281 2004-013 Ford Mustang Salween Extreme-FOR SALE 1999 Ford Mustang Cobra convertible SA-20 clone 2006 Dodge Charger R/T 2007 Jeep Grand Cherokee SRT8-SOLD 2002 Big Dog Pitbull-SOLD 2005-1343 Ford Mustang Saleen SC281. Barricade replica-SOLD 2011 Ram Express 2006-016 Ford Mustang Saleen Extreme-FOR SALE 2012 Ford F150 FX2 2007-300 Ford Mustang Saleen SC281-FOR SALE 2005 Ram SRT-10 RC CE #43-FOR SALE |
Yes Ive changed the belt there is no residue that I can see and sound seems like a bearing sqeaul however everything is brand new so I can't figure it out
You mentioned that you changed the water pump pulley but it is pressed onto the water pump shaft so if it were squeaking the water pump itself would have the bad bearing and need to be changed.
It felt fine last I spun it but I'll look into that also I was told about the front bearings in these blowers having a problem blowing out. Heard anything about that? Car only has 27k miles on it
There are known issues of the supercharger front cover leaking which can lead to internal damage. Remove the intake tube and check the snout for an oily residue near where the supercharger nose meets the main body. You may also want to check the oil level in the supercharger. If you have a leak or are low on oil I would recommend a supercharger rebuild.
This may sound far fetched, but I had a real nuisance squeak too. Turns out my belt was scrubbing the bracket for the alternator... You might could look at that
Mirror Caps, MRT Hood Struts, JLT Catch Can, Kooks LT Headers & Catted X, JLT Series 3 CAI, Bosch Injectors, HTO Plugs, 3.4 Pulley, KB Boost-A-Pump, SCT X3 Tuned by BRENSPEED, Chicane Brace, Pioneer AVH-P8400BH, White Extreme Splitter & Diffuser, MGW Shifter, Raptor Shift Light, 6K HIDs & LEDs, Stealth Bulbs, Steeda X-Brace, Corsa Sport Mufflers, Whiteline Watts Link & Rear Sway Bar, Slotted Rotors Front & Rear, 281 Grille, Dipstick, & Radiator Cover, GT500 Fan |
My apologies up front if this is redundant, are you using a piece of long wood or metal (long wrench or screwdriver) on the different housings of the suspected culprits with the other end against your ear or head in front of you ear? The other sound spotter trick is a length of 3/4 inch pvc tube to float near specific areas to help pinpoint the sound. The wood/metal rod trick is better for bearings and contact noise, the tube for exhaust leaks or just plain hard to reach into areas. My 2007 noise that I thought was the SC, was the plastic tensioner pulley that got swapped for the Ford metal one.
I am glad you mentioned that. I am currently having a squeak that increases as the RPM's go up like the OP. I borrowed a mechanical stethoscope from a friend to make sure it isn't my supercharger and it is coming directly from my alternator. How did you stop it from rubbing?
Black - 06-1279 - S281SC |
I put a GM pulley on that was a little taller and narrower. I now have a cross breed, but it doesn't squeak :)
Lol. Do you know the part number? I'll be checking this when I get home. Hopefully this is my problem, I really don't want to buy a new alternator.
I don't, it was on a desk at Atlanta Chasis Dyno so we tried it and it worked perfect
Ah, you lucky dog. Thanks anyway bud. 👍
Tags |
belt pulley problems, sqeauk, supercharger |
