Old 01-07-2016
18 With A Saleen's Avatar
18 With A Saleen 18 With A Saleen is offline
Default Q: Replacement Throttle Cable? - 2000 S281 SC
Hey all,
I have 00-210 S281 SC.
I need a new accelerator cable and i bought one for a normal manual gt.
However that cable is too short does anyone know where i can buy the correct one, or if there is a different year or model i can use.
THANKS!!!!
1991 Z/28 Camaro 350 TPI 5-Speed (SOLD)
2000 Saleen s281 SC .020 over forged internals 5-Speed
2006 Mustang V6 coupe
2001 F150
2006 F250
Old 01-07-2016
Or if you have one for sale that would be great as well
2001 F150
2006 F250
Old 01-07-2016
Try a 1996-98 SVT Cobra cable.
I am not sure if this was ruled-out before.
Old 01-08-2016
Okay I will look into it, if those don't work what about a 03-04 cobra does anyone know if those work.
2001 F150
2006 F250
Old 01-08-2016
Dave,
Just checked 98 cobra they are also too short. Have been searching 99-01 cobra and 03-04 Mach1 should work. Must be 40'' in length.
2001 F150
2006 F250
Old 01-11-2016
tfalk tfalk is offline
I would think one from an 03+ supercharged cobra would work, the throttle body placement is similar...
Old 01-17-2016
Hey guys i asked about this a while ago but I'm still searching and hitting dead ends. I have a 00 281 S/C and the throttle cable is broke and is the only thing keeping this car from being driven after a complete engine rebuild.
That being said I have tried, GT, 03-04 mach 1, old thunderbird cables that the parts number got referenced too, 1996-1998 cobra, Throttle cables none have worked. If anyone has had to deal with this before or knows what actually works that would be great. Hate that a throttle cable is holding me up from enjoying this car.
2001 F150
2006 F250
Old 01-17-2016
Haven't tried yet problem is all these cables are so expensive to go buy them and find out they don't work
2001 F150
2006 F250
Old 01-17-2016
I have tried:
1999-2000 GT
03-03 Mach 1/
1999-2000 Cobra/Bullitt
96-98 Cobra
2001 F150
2006 F250
Old 08-02-2017
OxfordS281's Avatar
Anyone know?
2002 #48 Mineral Gray Extreme
Old 08-11-2017
I don't exactly remember but I feel like a long time ago people had considerable problems It very well could be that you need a saleen specific cable.
My memory is really fuzzy though so i wouldn't swear to it. search throttle cable above and see if you get a hit.
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 08-11-2017
OxfordS281's Avatar
I believe it is Saleen specific...
Old 10-01-2021
Mustang Al Mustang Al is offline
Default Throttle cable
We have a 2002 S281 SC. We were told by Saleen that they used an 03-04 cobra throttle cable modified. I'm here to tell you I just ordered the cobra throttle cable and it is too short to work. I not sure what to do. Just bought the car for my wife.
Old 10-04-2021
Unisom Unisom is offline
I am also in the same predicament with my 2004 Mustang Saleen S281 S/C.
Initially I was informed by Saleen that they do not offer replacement throttle cables anymore. It was mentioned that this item was a modified cobra throttle cable.
I then asked if an 03-04 SVT Cobra Throttle Cable would work and to see if they could shed some light to this modification.
When I inquired Saleen about the modification, the response was the following:
"The documentation is not specific to the modification. It just says modified. I'm sorry I don't have more information for you."
Surely someone has found an alternate solution.
Could anyone shed some light?
Apparently there is a difference in a throttle cable from the supercharged model to the non-supercharged model as well
Old 10-12-2021
I am fortunate to live within a few minutes from the Saleen Performance Parts Center in Round Rock, Texas and while picking up some items from an order I placed, I asked the lady that was working about this situation on replacement throttle cables.
I believe she said her name was Molly and she actually provided me a part number and mentioned I should be able to purchase this from any Ford dealership. The part number is the following:
3R33-9A758-AC
She said this is the throttle cable that was used on my 2004 Saleen Mustang. She also said this was the same part for the non-supercharged versions and the supercharged alike.
She also mentioned this is the cable used on the Mach 1 AND the 03-04 Cobras.
It’s been my understanding that the throttle cable for the Mach 1 and the Cobras was different, but she looked it up on her computer and seemed confident in her response.
If someone tries this out with this specific part before I do, please post results!
I am working on other things on my car and its further down the priority list for now, but if I do try this, I will be sure to post results.
It may be a while; however, depending on the cost of the part from Ford, I may order it for now.
