Old 03-24-2019
Tirefriar Tirefriar is offline
Default S281 heat from trans tunnel
There seems to be quite a bit of heat coming from the trans tunnel, especially through the hand brake cutout on the center console. The console gets pretty hot as well. Is this normal? Car is n/a 5 speed.
Old 03-24-2019
Saleen206 Saleen206 is offline
Mine gets pretty warm too. You can check under the shifter boot too for anything allowing heat in.
06 Saleen s281 SC #206 / Black
Blue 39lb Injectors
3.6 Pulley
Saleen Airbox Lid
Saleen Hard Plastic Tube
Brenspeed E-Mail Tune
Exedy Mach 500 Clutch
Exedy Billet Steel Lightweight Flywheel
Cervinis C Style Scoops
Baer Eradispeed +2 Drilled/Slotted Rotors
Baer Eradispeed 14 in Rear Drilled/Slotted Upgrade
Old 03-24-2019
Ok, thanks. Car is new to me. Original owner had transmission replaced at Galpin, reason being it wasn’t engaging 1srt gear. Just want to be sure that I am not frying the trans.
Old 03-24-2019
It’s unlikely, you could check and make sure there’s fluid in it. I’d bet most is coming from the shifter area. Check around there to see if there’s holes. Maybe they forgot or ripped a boot. The shifter boot housing just pops out easily to check. But like I mentioned mine is usually a little warm too
Blue 39lb Injectors
3.6 Pulley
Saleen Airbox Lid
Old 03-26-2019
Aussie-Parnelli's Avatar
There was a insulator pad that went between the gearbox and floor, I bought one for my race car, I am pretty sure I got through Saleen around 2008-9
Not sure of part number but like most Saleen parts long gone.
There is no reason why you couldn't make one
Tony
2008 S302E #02 RHD Saleen Demo/Press
1966 Shelby GT-350 LHD
Old 03-26-2019
Tony
I presume the trans would need to be dropped to access the underside of the tunnel... Will get the car in the air to see. Will check on the shifter seal as well.
All Original Content Copyright © 1991-2019 Saleen Owners and Enthusiasts Club, LLC (SOEC). All Rights Reserved.
