Closed Thread
Old 06-08-2008
Default 2005-08 Saleen TSBs and Install Manuals
We're working to get the 2005-08 Saleen Technical Service Bulletins and Install Manuals online, but there's a lot of them.
If you need one in particular, please PM me and we'll expedite it for you.
I do want to thank former Saleen Techline ace Jorge Lopez and the people at Saleen Inc. for providing these to us.
Old 06-08-2008
Default 2007 PJ Instrument Cluster Removal for Reprogramming
Old 06-08-2008
Default 2007 PJ Black Paint Care
Old 06-08-2008
Default 2007 PJ Watts Link TSB
Old 06-11-2008
Default 2005-2006 Saleen S281 Brake Line Recall on 14" and 15" Brake Upgrades
Old 06-11-2008
Default 2005 Saleen S281 Supercharged Hood Bolt TSB
Old 06-19-2008
Default 2005-2008 Saleen 475 HP Upgrade Install Manual
Old 06-19-2008
Default 2005-08 Saleen Series VI Supercharger Maintenance Manual - Mustang & F-150
2005-08 Saleen Series VI Supercharger Maintenance Manual - Mustang S281, S302 & F-150 S331
File Type: pdf 05-08 Series VI Maintenance Manual - Mustang & F-150.pdf (729.7 KB, 409 views)
Old 06-19-2008
Default Saleen SPEEDLAB Superchargers and Boost Gauge Statement
It has come to our attention at Saleen that there is some confusion with regards to how our supercharger works and what kind of boost pressure it should create. The following information should help you and yours assist customers with any questions they may have.
The first thing that has come to our attention is customers and dealerships saying, “the boost pressure gauge does not move no matter how fast I’m going.”
The only time the vehicle will produce boost is when the car is under load, meaning hard acceleration in 2nd or 3rd gear. You may see boost in all gears at wide-open throttle but, the amount of boost you will see will be small (2-3 lbs. In 1st, 4th and 5th gear compared to the 5-7 lbs you may see under hard acceleration in 2nd or 3rd gear).
Our Speedlab supercharger works with a by-pass valve system similar to that of a 1993 Ford T-bird Supercoupe. When the air fuel mixture enters the inlet tube (the tube that connects the throttle body to the back of the supercharger) it has two routes it can take, either directly into the manifold or into the supercharger. When it gets routed to the supercharger the car makes boost. The way it gets routed to the supercharger is based on the by-pass valve and how much vacuum the car is making. When the car makes a lot of vacuum (hard acceleration) the butterfly that directs that air fuel mixture in the inlet tube closes and sends it to the supercharger thus, creating boost.
When the car is under normal driving conditions (even accelerating from a stand still to 80 mph) the butterfly in the inlet tube stays open, directing the air fuel mixture directly into the manifold thus, not making any boost.
Again the car has to be at wide-open throttle to produce boost.
PDF Download:
File Type: pdf SPEEDLAB SC AND BOOST GAUGE EXPLANATION.pdf (62.5 KB, 284 views)
Old 06-27-2008
Default 2005-08 Saleen Windshield Banner
Old 07-02-2008
Default 2005-06 Knocking Noise from Front End
File Type: pdf STB06-009 front end knocking noise.pdf (144.9 KB, 479 views)
Old 07-23-2008
CRF118R CRF118R is offline
How much boost should the Extreme be producing under the loads you suggest int the boost statement?
Old 07-23-2008
saleen104 saleen104 is offline
Should be 12 lbs. Thats what mine is producing.
Old 07-23-2008
teamgsxr teamgsxr is offline
10-12 lbs depending on throttle input.
Old 07-23-2008
Thanks again.
Old 07-30-2008
abbas abbas is offline
Default TSB for car seats
Any TSBs for the flap in the front of the car seats being loose?
Old 07-30-2008
NO, but Saleen is well aware of this issue. they usually have the deler sublet the work and then reimburse the dealer.
Old 07-30-2008
my seats are not under warranty anymore.... when they were, I took it to the dealership and they said that they couldn't do anything about it.
Old 07-30-2008
you can take it to any local upholstery shop and they can tighten up the hog rings on the cushion.
Old 09-30-2008
Aussie-Parnelli's Avatar
Default Salley Pulley Installation TSB
Hi Listers
Is there a TSB on installing Saleen underdrive pulleys.
I have managed to fit crankshaft and water pump pulleys but having great difficulty in removing nut on Alternator pulley.
I do have the splined tool.
Tony
South Australia
1966 Shelby GT-350 LHD
Old 10-01-2008
Unclemilti Unclemilti is offline
Originally Posted by Aussie-Parnelli View Post
Hi Listers
Tony
South Australia
I didn't even have to use the tool, because I couldn't figure out where to insert it .
I held the pully with my hand, and then used an impact gun to take the nut off.
You WILL need an impact gun.
Old 12-06-2008
ultamax ultamax is offline
Default TSB for struts
I've read a couple threads talking about an easy fix for the strut clanging, but isn't there a TSB for it?
I'd like to have more info and, if available, something more to look at (i.e. diagram, photo) in case I would be better off just fixing it myself. What would that torque spec be then? I'm not mechanically apt but did the cold-air so this is probably pretty similar. Thank you.
Old 12-29-2008
Default All Saleen Vehicles - Flat Spotting on Tires - STSB08-009
All Saleen Vehicles - Flat Spotting on Tires - STSB08-009 - December 1, 2008
SERVICE INFORMATION: Procedure to repair "flat spotting" on tires that have been sitting for a period of time.
IF YOU CONFIRM: The vehicle has a vibration while driving.
File Type: pdf Flat_Spotting_On_Tires_STSB08-009_SOEC.pdf (451.7 KB, 322 views)
Old 12-29-2008
We have this one posted earlier in this thread:
Old 12-29-2008
Yes, I printed that one for reference. Figured it would be same, or very similar, process for my '07. I guess there isn't a formal tsb listing '07+ vehicles then. Thanks!
Old 01-05-2009
pacettr's Avatar
pacettr pacettr is offline
HID install?
07 Saleen Parnelli Jones S-302 #494
1 of 1 With Factory-Installed Scenic Roof
Supershaker, 3.0 Pulley, 60# Injectors, FGT Pumps, Extreme H/E, Kooks LT's + O/R H-pipe, Spydershaft
JDM Tune
89 GT Vert
Too Many Mods to List
Old 01-05-2009
2005-08 HID Mustang and S-Line Saleen Installation Manual PDF
Old 01-07-2009
pacettr's Avatar
SuperShaker?
JDM Tune
89 GT Vert
Old 01-19-2009
justrockin05 justrockin05 is offline
Where is the 475hp upgrade kit install manual that was on here a couple weeks ago? Thanks.
Old 01-19-2009
You missed it... it's on the previous page: http://saleenforums.soec.org/showpos...27&postcount=7
Old 05-16-2009
Steve91386 Steve91386 is offline
Anyone have the installation / wiring instructions for the Heritage/PJ decklid panel and body kit. I picked up a full kit directly from Saleen and there was all the pieces, hardware kit, etc but no installation instructions.
Thanks!
Old 05-18-2009
pacettr's Avatar
Originally Posted by pacettr View Post
SuperShaker?
JDM Tune
89 GT Vert
Old 05-18-2009
Shaker install manual?
Old 05-20-2009
2005-09 S-Series Body Kit Installation Manual.pdf
Old 05-20-2009
2005-09 Rear Window Louvers Installation Manual.pdf
Old 05-20-2009
Thanks, the louver install guide will definitely help!
Although, similar, the S series is a little different than the Heritage series, especially when it comes to the license plate bracket installation and wiring.
If you had ANY info on the install of the Heritage series components that would be a complete life saver!
Old 05-20-2009
2005-09 Saleen Heritage Body Kit Installation Manual.pdf
Old 05-20-2009
2005-09 Saleen Supercharger + Supershaker Upgrade Kit Installation Manual.pdf
Old 06-08-2009
Heat exchanger install please?
Old 06-11-2009
See pages 80-81 of the 2005-09 Saleen Series VI Supercharger - 475 HP Installation Manual. It's a big download, so save it to your hard drive.
Old 06-11-2009
Gives me a damaged file note?
Old 06-11-2009
Sorry about that -- it's 58MB and we had some trouble on the upload.
Old 06-12-2009
Cool, it worked this time. Thank you!
Old 06-13-2009
pacettr's Avatar
Extreme heat exchanger install?
JDM Tune
89 GT Vert
  #45
Old 06-15-2009
No, replacing a friend's 'regular' H/E. Did you upgrade yours and was it helpful/worth it?
  #46
Old 06-17-2009
pacettr's Avatar
I was hoping for the install manual
I have the extreme h/e. I live in Oklahoma and it gets pretty hot. No sense taking any chances...
JDM Tune
89 GT Vert
  #47
Old 06-24-2009
We're closing this thread and moving reference documents to a new section: http://saleenforums.soec.org/forumdisplay.php?f=102
Closed Thread
