Go Back   The Saleen Forums at soec.org > Saleen Enthusiast Forums > TSBs, Install Manuals and Service Documents
TSBs, Install Manuals and Service Documents Technical Service Bulletins and other resources to help you keep your Saleen running in top form. Full access is available to forum registrants. If you can't find a document, please PM us or use the Contact Us form at the bottom of the page with year, model and concern.
Closed Thread
Old 06-19-2008
Default Saleen SPEEDLAB Superchargers and Boost Gauge Statement
It has come to our attention at Saleen that there is some confusion with regards to how our supercharger works and what kind of boost pressure it should create. The following information should help you and yours assist customers with any questions they may have.
The first thing that has come to our attention is customers and dealerships saying, “the boost pressure gauge does not move no matter how fast I’m going.”
The only time the vehicle will produce boost is when the car is under load, meaning hard acceleration in 2nd or 3rd gear. You may see boost in all gears at wide-open throttle but, the amount of boost you will see will be small (2-3 lbs. In 1st, 4th and 5th gear compared to the 5-7 lbs you may see under hard acceleration in 2nd or 3rd gear). Extreme models should produce 10-12 lbs under load, depending on throttle input.
Our Speedlab supercharger works with a by-pass valve system similar to that of a 1993 Ford T-bird Supercoupe. When the air fuel mixture enters the inlet tube (the tube that connects the throttle body to the back of the supercharger) it has two routes it can take, either directly into the manifold or into the supercharger. When it gets routed to the supercharger the car makes boost. The way it gets routed to the supercharger is based on the by-pass valve and how much vacuum the car is making. When the car makes a lot of vacuum (hard acceleration) the butterfly that directs that air fuel mixture in the inlet tube closes and sends it to the supercharger thus, creating boost.
When the car is under normal driving conditions (even accelerating from a stand still to 80 mph) the butterfly in the inlet tube stays open, directing the air fuel mixture directly into the manifold thus, not making any boost.
Again the car has to be at wide-open throttle to produce boost.
PDF Download:
File Type: pdf SPEEDLAB SC AND BOOST GAUGE EXPLANATION.pdf (62.5 KB, 239 views)
Old 09-21-2008
Default 1999-2004 S-Series Mustang Reference Documents
1999-2001 Saleen Series II Supercharger Installation Manual
File Type: pdf 1999-2001_Saleen_Series_II_Install_Manual.pdf (3.21 MB, 396 views)
Old 12-29-2008
Default 2002-2004 Saleen Series IV Supercharger Installation Manual
File Type: pdf 2002-2004_S281_Series_IV_Install_Manual.pdf (1.30 MB, 308 views)
Old 04-30-2009
Default 1996-2004 Saleen Twin Gauge Pod Installation Instructions
File Type: pdf 1996-2004_S281_Gauge_Pod_Kit_Install.pdf (1.05 MB, 465 views)
Old 07-16-2009
1999-2004 Saleen Mustang Body Kit Installation Manual
Closed Thread
